2/1/9 - UPDATE -
Lifter pics in post # 97 of page # 7
9/6/8 - UPDATE -
Well I finally took time to list the parts used in replacing the camshaft. Sorry for the delay.
Part____________________Part Number ___________Qty. ____Cost Each
Camshaft--------------038-109-101-R--------------------1-------------$699.51----------------$699.51
Camshaft Bearings-------------038-103-673-B-GLB------------10------------$13.50-----------------$135.00
Cam Bearing Cap Bolts------038-103-714-----------------------10------------$4.63-------------------$46.30
Cam Followers------------------038-109-309-C---------------------8-------------$42.37-----------------$338.96
Sealant-----------------------------AMV-174-004-01------------------1-------------$49.23-----------------$49.23
Rocker Arm Shafts------------038-109-527-AF--------------------2------------$285.17----------------$570.34
Rocker Arm Shaft Bolts-----038-103-714-A----------------------8------------$6.02-------------------$48.16
Rocker Arm Adjusting
Screws [w/ shaft]--------------WHT-000-530------------------------0------------$4.32--------------------$0.00
Cam Shaft Seal - sprocket
end [w/ TB kit]------------------068-103-085-E-----------------------1------------$0.00
Tandem Pump Seal-----------038-145-215--------------------------1-----------$11.25------------------$11.25
Cam Tool - Holder-------------Matra T10051-------------------------1-----------$74.50-----------------$74.50
Cam Tool - Sprocket
Puller-------------------------------Matra T10052-------------------------1-----------$89.95----------------$89.95
TOTAL---------------------------------------------------------------------------------------$2,063.20
7/6/8 - UPDATE -
Some followers are in fine shape, others not so good, this was the worst one.
On the bearings, just the lower halves have notable wear. Work is done, and car is running well.
Thanks to TDIClub members.
7/5/8 - UPDATE - Almost done replacing camshaft and related parts. Two followers were badly worn, one with cracks and a small hole.
These cam lobes are heavily worn too.
As to the groove on the injector lobe for cylinder #2, it is from the follower and its lobe having worn enough that the follower was hitting the injector lobe.
Does anyone have any thoughts of how the groove got into the injector lobe of cylinder #2? This on my '04 Golf PD TDI, with 247,000 miles. Found this as I was going to change the injectors. But now need to think about if other work should be done also? Have always used 505.01 oil and OEM oil filters.
It is only about 1/4 of the way around the lobe. The rocker arm roller has just the thin line all around it, no wider marks.
And how likely this is to grow?
Cylinder #2 intake lobe - left / injector lobe with groove – center / exhaust lobe – right. Horizontal lines on injector lobe are reflection of spring on injector.
One side of rocker arm roller, cylinder #2.
Other side of rocker arm roller, cylinder #2.
Note intake lobe wear, on cylinder #2.
9/6/8 - UPDATE -
Cam Tool - Sprocket
7/6/8 - UPDATE -
