Birdman
- Joined
- Apr 7, 1999
- Location
- Near Hagerstown MD.
- TDI
- Jetta 2001 Died by Truck one snowy day. Jetta 2003
With the cam bolt tighten down right there is no way it is going to spin.
I already asked the installer that. His response was that the bolt was checked and found to be tight. This was not the cause.There may be another possibility of what happed. Is it possible that the cam gear may have spun loose (or just partially loose) just as #2 piston was coming up? This would account for the broken valves only in that cylinder. Any thoughts?
Steve
Sure, blowing someones motor isn't very conducive to friendship, but I've made 5 friends for my 5 belt changes.I rarely work on other peoples vehicles. I like keeping friends, and something like this just isn't very conducive to keeping them.
actually when the "timing slips" the cam gets retarded, thus the exhaust valve open while the piston comes to the top#1 and #3 look like the exhaust valves hit the pistons. If the timing slips, then the cam is advanced too far, which would cause the piston to push (make contact) the valve shut on the exhaust stroke.
I always knew you were a bit odd, but seriously, ive never messed up a TDI. No other forum member I know of has wrecked an engine during maintence. Ive never even put a scratch in a members car in well over 100 timing belts, with at least 40 this year alone. I have literally been booked this entire year, saving people thousands of dollars, and getting the job done correctly every single time. I SERIOUSLY doubt ANY dealer in the entire USA can claim a success rate anywhere near mine, or the other Timing belt pro's on these forums like MOgolf, DBW, and Herm.LESSON LEARNED:
Only let QUALIFIED people work on your car... not some guy in his backyard. Sure, Volkswagen mechanics can make mistakes too, but at least its *their* mistake and you can drag them into court and dip into their billion-dollar pocket for damages.
When it comes to cars under warranty, I *always* go to the dealer. If you don't go to the dealer for service, it's 99.5% certain they'll deny warranty (reference: Toyota ignoring oil changes done at Jiffy Lube...and refusing to honor warranty).
Hey Mary. Please learn to read: "When it comes to cars UNDER WARRANTY, I always go to the dealer." See where it says under warranty? After warranty you can do whatever the hell you want.I would much rather have a Fred's "backyard" mechanic working on my car than my dealer! I can't wait for my warranty to be over and you can sure as h*&% believe I'll be asking a local member to do my belt change.
Now learn to control your anger. I'm sorry you don't like my opinion, but I'm not changing it. So please stop yelling at me.Troy, that is absolute BS!
Tulley has a good reputation!!!That said- I am glad that I took VW TB job to
Tulley VW of Nashua - $550 for timing belt (I had waterpump changed at same time and fuel-filter)
Tulley VW treated me very nicely- explained everything and did a fine job IMO- wish I bought car there.
I would push my car past VW dealer where I got all my warranty service!!!
