made it 1.25" thick 6061
i had to slightly increase the angle 10 deg to clear the Jeep starter hood is no concern as there was a inline six in there, plenty hood clearance.
i plan on using the vw accessories, and adding AC down the road.
all parts are drawn in solidworks, the plate is cut on industrial cnc router.
i would rather not make custom hoses if possible, I will probably make a block that adapts the jeep line into the vw pump.
haven't got the the gauges part of the wiring, i will probably just piggy back the jeep sensors.
I will probably use factory CPS to run tachometer, I doubt I need adaptors ect. Factory computer will remain
X2Hoping for 30mpg
started making the harness. i cant use the coolant glows, will that throw a code with them missing?
It throws a code on my AHU... but I don't think it causes any issues other than the CELstarted making the harness. i cant use the coolant glows, will that throw a code with them missing?
from looking at the diagram no signal goes back to the ecu for the coolant glow plug, i am thinking if there is a code it can be alleviated by adding two resistors to the lines that used to feed the relays.
