TDIJ
I think you should just weld it all up as it sits now... won't have to worry about twist!
I like your mounting solution. Very similar to mine.
=Jason-
I did that to help with the vibration. You're gonna see how bad those vibs are pretty soon. It's like a massage chair, all the timeyours looks like you may have issue with the engine twisting under torque, mine is solidly mounted to the engine with 8 bolts. yours looks to be rubber mounted to the engine on pedestal type rubber mount.
=Jason-
On the last I'm sure it is solely for double isolation.so you are only running effectively one mount on the front and one on the transmission?
I just don't see how that is going to work, the pendulum mount in the OE configuration is used in conjunction with 2 additional mounts to keep the engine from rotating, you may have an additional side mount, I just cant see it in the picture.
also confused as to why you decided to have two rubber end mounts then a rubber middle mount on the cross bar?
Swap is doing well, it drives up and down the road no problem. There's an arm's length list of cosmetic/small details still to finish but moving all over(just got back from Africa, most likely heading to afgan in a month) has really delayed the progress.Logs, How is your swap coming along?
