'96 B4 Sedan in Arizona Junkyard, anyone need parts?
snoopy smiles
tuscon, arizona
B4 and Touareg
We moved to Prescott Arizona area last march and I finally went to the local U-Pick It a month ago. There was only one white '96 B4 GLX and it was pretty much stripped, but I did manage to get a few pieces off it like the rear ABS sensors and shield mounts.
Yesterday there was a red '96 B4 TDI sedan that arrived and it's complete and unmolested. I grabbed the cluster, front marker lights, and passengers door handle, and today I'm going back for the ECU (GQ). Does anyone need any other parts from it? It's still complete at this point and in decent shape with no rust (I love Arizona). It has a tan interior and sunroof, mileage unknown as I haven't powered up the cluster yet. Keep in mind I won't ship large parts like body panels, seats, or doors, but can pull them if you want to drive to pick them up. Shipping small parts is bad enough. There is also an A4 TDI 5 speed if anyone needs parts.
I am not looking to make this into a business, nor do I want to spend hours pulling parts. I am merely doing this because I know how hard some of the parts are getting to find. There is only 1 B4 sedan (TDI) local to me that I have seen, and it's a POS to the point I haven't wanted to speak to the owner for fear he'll ask me to "help" with it. I am all too familiar with how that works.
Let me know what might be needed and I'll see what I can do. Include your phone number so we can talk and call in real time when I'm there in case the part isn't in good shape. I don't want to pay for something and then get stuck with it because you decided you didn't want it at the last minute.
I am looking for seats for a B4 - am about 3 hours from you and would be glad to come and get them. Would like to talk with you. 541-591-1430 Thank you
MarsBar
San Jose, CA
B4V#2 "Flash", 2000 Jetta GL, B4V#1 "PaTuDI" (2008-2018 RIP)
Need the drivers side side marker "light" (the triangular shaped one), mine fell victim to a car wash. Also the sun visor clips if still available. Only need the drivers side, but will take both.
kmjunge
Idaho
Eurovan 1z Conversion, 1998 Jetta AHU, 2013 Jetta Sportwagen
I don't suppose there is a T24 orb of death connector available on one of these cars. I'd be interested in one or two of those.
kmjunge
Idaho
I'll take the one from the B4.
PassatLife
Coquitlam, BC
1996 Passat Tdi Wagon
Are the rubber spacers on the rear struts still there? I threw my originals out when I switched to coilovers but need them now as I'm going to Bilstein HDs
Steve Addy
Iowa
97 Mk3
Are they the same? Don’t need them, just curious.
-Todd
No they aren't they same.
This is what VW says uses the T24 (3A0973103) connector...but even that I think is not accurate. I would bet that the VR6 Eurovan does not use the same one, and notice that the B4 TDI cars are not listed at all, which we know is not correct since they should be there.
Further, VW didn't bother to denote the engine for the Golf or Jetta, which we know has to be TDI to use the same connector. This is why I take what VW says with a huge grain of salt....
Steve
EDIT:
Oddly enough the above is only half right. The part number on the female side of the connector (harness side) I have is 3A0973121. The part number on the male side (engine side) of this is 3A0973131 and the application list is more complete if still less than specific about the Mk3 and B4 engines it covers.
It still doesn't change the fact that the only sources now for these are used pieces, at least unless Heritage has some, which I haven't checked on.
Steve
Abacus
That helpful B4 guy
Only the B4V left
The struts are still in it, but I’m not removing the interior to get the struts off, then disassembling them in the junkyard using spring compressors just to get the rubber spacers to ship them to Canada. Not unless significant $$$ comes my way first. Sorry.
kemalik84
Austin Texas
Touareg TDI, B4 97, 96B4V, MK5 TDI Jetta, Vanagon(non-TDI) soon to be converted
How many miles were on it. Could you get the harness for the cluster off of it?
PassatLife
Coquitlam, BC
Etka is giving me 3A0973131 for the engine side, and 3A0973103 for the chassis sid
No worries. Might just order a set from Latvia or something. For some reason I thought the sedans had an easier time of accessing the rear struts but I just looked it up and it seems just as annoying as the wagons....
Steve Addy
Iowa
97 Mk3
Sedan and wagon have the same suspension although spring rates are different. I dismantled a wagon rear suspension a year or so ago but I don't remember whether I kept the cushions or not. I was after the springs so probably not.
Steve
Steve Addy
Iowa
97 Mk3
Mark
They don't appear to be readily available anywhere. I have looked in the aftermarket suppliers and they aren't carried anywhere here. Maybe Eastern Europe, but not in the US. They're not sold as part of the rear strut mounting kit either. It's unfortunate, because they do need to be replaced at some point.
Steve
333512149B
PassatLife
Coquitlam, BC
Apologies, I thought he was mentioning #4.
I’ll see what I can do.
Cheers, thanks!
They do need to be dismantled to removed #6 though. The struts shouldn't be under much tension iirc. When I dismantled mine I just took the nut off with an impact and the spring basically fell off, didn't shoot anywhere or need a spring compressor.
Mark
Steve
333512149B
Yeah 6 is NLA everywhere in the western hemisphere. There seems to be quite a few available from an Ebay seller in Latvia but would come out to almost $60 each side after shipping. #20 is also NLA everywhere if you wouldn't mind saving that as well
QuadRacer31
Louisiana, U.S.A.
96 Passat TDI
I need the trim for the exterior of the C pillar. Its about 4-5 inches long and maybe 2 inches high. I also need the rear view mirror covers for the inside of both front doors. Thanks.
BamaB4S
AL
1996 Passat
If the triangular plastic screw cover trim pieces near the front/back windows are black, and still available, I would be interested.
Steve Addy
Iowa
97 Mk3
Not gonna re-read 80 posts going back 2 months to make sense out of what looks like nonsense.
What doesn't look like nonsense, is that Abacus generously offered to pull parts for people who need them, and some of them are taking his generosity for granted and demanding way too much.
Mark did actually mention in the first post that he'd pulled the cluster, so the question about miles was not unreasonable.
Steve
BamaB4S
AL
1996 Passat
Enjoying reading 90+ posts and learning A3/A4, B4 GLX/TDI intricacies from the knowledgeable VW veterans.
On the other hand, roadtripping ~3,400 miles to inspect this B4 example is also tempting. :cool:
Steve Addy
Iowa
97 Mk3
I may have some of those somewhere...seems I got several once, what color are you looking for?
Steve
snoopy smiles
tuscon, arizona
B4 and Touareg
I am needing the drivers door window guide and regulator. Would you be willing to pull them - for compensation? Thank you for your reply. 541-591-1430 Roxanna
jdulle
Ithaca, NY
96 B4, 97 B4
I fixed the issue with the shift tower, so I am set on that. Any chance you could get the climate control unit in the next month or so?
