Mcgink
- Joined
- Oct 15, 2004
- Location
- South of Boston MA
- TDI
- I-Red,"The Passat formerly known as Harlequin" 97 B4, a non VW GTDI too
I believe so, part of the MFA but if you're upgrading .
I will see what condition it's in when I go back. They're pretty big so I'll have to find a box.Hello i have a fedex account for shipping a piller is about 2 feet long need a tan one with all the Screws hole covers you can find. As far as the Harnesses it could be left over from even a car that looks stripped thank you
I have had many of those off and they shouldn't be too pricey. I think they're around $15 each.I'm interested in the front passenger door latch mechanism 357 837 016G. Maybe pull them all, they are discontinued and hard to find, I think they will all fit in a small flat rate box... Also as many driver door plastic clips that connect the interior plastic part of the door to the metal as you can get. The clips that fit into the metal of the door and that the door plastic screws into. Also a door switch 3A0 947 561A.
What is the part number for the temp sensor, or where is it located.
Someone's adding MFA it sounds like....In a VR6, the outside temp sensor lives in the lower grill under the bumper and the harness routes back to the fuse panel through a rubber plug under the master cylinder.
It is highly doubtful since, as I explained previously, the B4 GLX is stripped and the TDI never had one.Hello if you fine a Outside Temperature harness Complete will pay up thanks
I pulled and installed one in my 1990 B3V wagon when I did the TDI conversion, but I don't think I got any more than the one.I can email pictures of the Temperature harness or how do you post a picture here?
I know there is one there, I'll have to head back and see what I can grab. They're only open when I'm at work though, and we're gone next weekend for Thanksgiving, but I'll go as soon as I can. How soon do you need it? I may have one in my parts stash I can send and then replace it with the one from the yard. I'll have to check since I don't know what made the trip west and what didn't.I suppose I am too late, but if you are back there I could use the interior HVAC control panel. I was going to buy one from ToddA1, but I didn't move fast enough and it is sold now.
Yes, I know. You've posted it 3 times in this thread alone. There is one there but I did not have enough time to remove it with the other items I needed to get. Just be patient. The temp sensor and harness is not there.Hello or the tan A piller Trim and screw hole covers
The GLX still has it, but it's a little bent in the front from when they pulled the engine and tranny.Steve Addy said:That car also had the uber rare center exhaust cover for the tunnel...haven't seen too many of those!!
That's pretty shocking after 25 years it's still on the car, so many of them got tossed in the trash at some point, especially if they had exhaust work done.The GLX still has it, but it's a little bent in the front from when they pulled the engine and tranny.Steve said:That car also had the uber rare center exhaust cover for the tunnel...haven't seen too many of those!!
One sold on Ebay in September of this year...Hello if you fine a Outside Temperature harness Complete will pay up thanks
So you bought that one on ebay and it ended up being cut?Yes i bought the ebay one it had Cut Wires was Hopefully Trying to get a Better Example of it
Yes, it's not really that complicated, just two wires that run uninterrupted from the sensor to the fuse panel. They run through their own rubber grommet too.Doesn't that wire go all the way through the firewall with no junction until the CE2 block? I could be wrong, since it was years ago that I dug one of those out, but that seems like a lot of work for a part that's likely getting hacked into a non-OEM car. Especially if it's going on ebay (mine didn't).
