dieseldorf
There is a general expectation that xW30 oil would offer 2 - 4% better fuel ecomony compared to a xW40 oil. However, can we really measure that from tank to tank?
This is not to be critical, but the only way you are going to get better start up protection between a 5w30/5w40 oil is to go to a 0w30/0w40 !! ?? W refers to "WINTER", even as it is almost always referred to colloquially as WEIGHT. ZERO winter viscosity is better than (thinner) 5 winter viscosity, for example.Xavior said:Excellent read on the topic guys, but i still find myself torn on what is ideal to use. Been using Castrol 5W40 since the first day of buying the car even after the warranty has expired. But i mean if i can get better protection and better mpg im always looking for alternatives. I understand that w30 oil would provide better protection hypothetically at startup because its lighter and it can be moved easier under colder temperatures. But, that doesnt for sure mean it does. There have been many opinions here and i find myself just stuck on the fence here..
thats only the US market . German cars use INA made liftersCool Breeze said:I was reading today that back in mid 2000's the big players who made flat tappets went out of business and the void was filled with cheaper parts. Oil formulation changes are also suggested but IMO it's probably a combination of the two. Sounds like a tough spot.
Maybe that's cause?
http://www.hotrod.com/techarticles/engine/flat_tappet_cam_tech/index.html
In a multigrade oil, a 5W-40 and a 5W-30 oils are theoretically have the same cold temp protection, since they're both a 5W grade viscosity oils. The W stands for Winter. However, 40 weight grade oil has better high temp protection than the 30 weight grade oil.Xavior said:.....But i mean if i can get better protection and better mpg im always looking for alternatives. I understand that w30 oil would provide better protection hypothetically at startup because its lighter and it can be moved easier under colder temperatures...
Snood, the PD cam/lifter failure is becoming a wild goose chase.Sloppy Snood said:So....are we to the point where a "minimum viscosity" value can be surmised for the PD camshafts (BHW or otherwise)?
Maybe a "5W-35" class of oils?
raybo said:The Mobil1 ESP 5w30 is the closest to 5w40 of all the 507.00 oils. Thicker than other 507.00 oils, it also meets MB 229.51 and is almost as thick as the ESP 5w40 Formula M.
Ray
TDI POWERKAlaBenne said:Engine Type: BHW
Miles on unit: 138060
Miles on oil: 10364
Oil: Mobil 1 ESP formula 5W-30 507.00
Wear Metals:
Fe: 36
Cr: 1
Ni: 2
Al: 6
Cu: 3
Pb: 4
Sn: 0
Cd: 0
Ag: 0
V: 0
Contaminant Metals:
Si: 3
Na: 4
K: 4
Multi-Source Metals:
Ti: 0
Mo: 81
Sb: 0
Mn: 0
Li: 0
B: 99
Additive Metals:
Mg: 9
Ca: 1519
Ba: 0
P: 896
Zn: 1062
Fuel: 0.4%
Soot: 0.3%
Water: <0.1
Vis @ 100C: 12.6
TBN: 2.88
VS non PDspfrancis said:Jetta TDI 2006- 50K UOA
Wanted to post my numbers, as I was worried about a few numbers:
Aluminum: 12
Chromium: 2
Iron: 47
Copper 6
Lead 3
Tin 1
Molybdenum 87
Nickel 2
Manganese 1
Siliver 0
titanium 0
Potassium 18
Boron 97
Silicon 5
Sodum 5
Calcium 1194
Magnesium
Phosphorus 779
Zinc: 1032
Barium 0
SUS 66.1
cSt Viscosity: 11.92
Flashpoint in F 415
Fuel TR
Antifreeze 0.0
Water 0.0
Insoluble .2
Their summary was: Wear was generally above avg, in the first sample from your Jetta. Aluminum and Iron were high enough to show mild piston scuffing, though nothing read high enough to warrant serious alarm. Universal avgs for the VW 1.9 are based on an oil run for ~8K. Your longer oil run likely contributed to the above avg, but we don't think that the oil was run too long. The trace of fuel isn't a problem, and no other harmful contaminatns were found. The viscosity of the oil read in the 10w/40 range.
The other number that they didn't comment on were Molybdenum, Boron....Any think I should be worried, or change something. I'm thinking that I need to go to 8K changes. Since I have been putting in Mobil 1 ESP 5w30, I thought I was safe going with the 10K service recommendation of VW.
Rev A: SPFrancis UOA addedMarbleTDI said:Year:2002 TDI
Mileage:103,520
Oil Mileage: 7,832
Oil: 5w-30 ESP Mobil 1 507
Fuel: #2 Diesel diet varies with brands and sources.
Additives: Stanadyne Performance Formula; every tank 8oz. for the past 12 or so fill-ups.
Used Power Service once (white bottle) prior to Stanadyne.
Additional Info: Did not sample the previous oil when drained. Vehicle was purchased with previous oil.
Lab Comments: Compartment wear is normal. No problems indicated at this time. Continue sampling at normal interval.
Copper 3
Iron 43
Chromium 2
Aluminum 4
Lead 3
Tin 0
Molybdenum 87
Silicon 0
Sodium 10
Potassium 1
Calcium 1693
Magnesium 12
Zinc 1151
Boron 147
Phosphorus 1087
Silver 2
Barium 0
Nickel 1
Cadmium 0
Titanium 0
Vanadium 0
Manganese 0
Soot 55
Oxidation 8
Sulphur-product 0
Water NEG
Fuel Dilution NEG
Antifreeze NEG
Viscosity 13.3
I am comparing apples to apples not apples to oranges.Dimitri16V said:.....
Iron and aluminum are lower than before when M-1 5W-40 TSUV was used. ....
Dimitri16V said:Date: 12/23/2009
Engine Code: BEW
Miles/oil: 6,400
Miles/unit: 187,000
Oil Type: German Castrol 0W-30 505.00 , SL
Fe Iron: 24
Cr Chromium: 1
Al Aluminum: 6
Cu Copper: 1
Pb Lead: 2
Sn Tin: 0
Moly : 258
Nickel : 0
P: 1257
Zinc: 1370
Boron:10
Calcium:3809
Additive : MoS2 , ZDDP
Visc @ 100C : 13.11
Soot : 0.4 %
Fuel : <0.5 %
Date: 10/15/2009
Engine Code: BEW
Miles/oil: 10,000
Miles/unit: 180,000
Oil Type: M-1 TDT 5W-40 CI-4+
Fe Iron: 33
Cr Chromium: 1
Al Aluminum: 6
Cu Copper: 2
Pb Lead: 1
Sn Tin: 0
Moly : 227
Nickel : 1
P: 1226
Zinc: 1465
Additive : MoS2
Visc @ 100C : 15.81
Soot : 0.3 %
Fuel : <0.5 %
Date: 06/16/2009
Engine Code: BEW
Miles/oil: 10,000
Miles/unit: 170,000
Fe Iron: 20
Cr Chromium: 1
Al Aluminum: 7
Cu Copper: 2
Pb Lead: 2
Sn Tin: 0
Moly : 147
Additive : MoS2
Visc @ 100C : 15.25
Soot : 0.3 %
Fuel : 2.5 % ( had a misfiring injector )
Date: 03/11/2009
Engine Code: BEW
Miles/oil: 9,000
Miles/unit: 160,000
Oil Type: ELF EVO 0W-30
Fe Iron: 24
Cr Chromium: 1
Al Aluminum: 5
Cu Copper: 2
Pb Lead: 1
Sn Tin: 0
Moly : 202
Additive : MoS2
Visc @ 100C : 10.68
Soot : 0.3 %
Date: 12/11/2008
Engine Code: BEW
Miles/oil: 10,500
Miles/unit: 151,000
Oil Type: Mobil-1 TDT 5W 40 CI-4
Fe Iron: 31
Cr Chromium: 1
Al Aluminum: 5
Cu Copper: 2
Pb Lead: 1
Sn Tin: 0
Moly : 64
Visc @ 100C : 15.28 , slightly on the high side
Soot : 0.4 %
Date: 8/29/2008
Engine Code: BEW
Miles/oil: 10,000
Miles/unit: 141,000
Fe Iron: 33
Cr Chromium: 1
Al Aluminum: 5
Cu Copper: 2
Pb Lead: 2
Sn Tin: 0
Moly : 352
LM MoS2 additive used
Soot : 0.7 % ( sample saw extended idle time and heavy AC use )
Date: 5/19/2008
Engine Code: BEW
Miles/oil: 10,000
Miles/unit: 131,000
Fe Iron: 20
Cr Chromium: 1
Al Aluminum: 6
Cu Copper: 1
Pb Lead: 2
Sn Tin: 0
Moly : 0
Here is mu 120K analysis on my 04 PD. oil used Elf Solaris 507.00 for 9,000 miles.
Alum : 8
Cromium : 1
Iron : 29
Copper : 2
Lead : 2
Tin : 0
Moly : 25
Nickel : 1
Manganese : 1
Silver: 0
Ti tanium: 0
Pottasium : 3
Boron : 12
Silicon : 2
Sodium : 6
Calcium : 1774
Magnesium : 79
Phosphorus : 703
Zinc : 842
Viscosity @ 210F : 64.3
Viscosity @ 100C : 11.42 ( CST)
Fuel < 0.5
Soot : 0.3
TBN : 3.2
Iron and aluminum are lower than before when M-1 5W-40 TSUV was used. But I suspect leftover 505.01 spoiled that analysis. To verify I should go back to 505.01 oil and retest. For now , M-1 TSUV went back in after I used the Elf 507 for 12K miles.
haha that made my dayT_D_I_POWER said:Yeah..with the extra additive he added to the oil, anybody can bring his/her UOA wear metals down. Is not a rocket science.
http://www.youtube.com/watch?v=pSxbmUcR8ao
that's BS .Despite the pains taken in developing special flat-tappet camshaft wear tests that these new oils must pass and the fact that the ZDP level of these new oils is comparable to the level found necessary to protect flat-tappet camshafts in the past, there will still be those who want to believe the myth that new oils will wear out older engines.
Come on now Dimitri16V......if the information is in print, it must be true, right?Dimitri16V said:the only myth I see here is that artcicle
the oil was kept for 10,500 miles. It was tested earlier to evaluate the increase in ZDDP level using the additive since it was the first time I used it. Another sample was not resubmitted since wear looked already good at 6400.T_D_I_POWER said:Great???
UOA taken at 6400 not at full 10,000 miles
Additional MoS, ZDDP were added
Nice responseYeah..with the extra additive he added to the oil, anybody can bring his/her UOA wear metals down. Is not a rocket science.
have not seen any benefit but being only $6 , I figured it's worth a try.Sloppy Snood said:Come on now Dimitri16V......if the information is in print, it must be true, right?
Your molybdenum disulfide additive is Lubro-Moly, correct? Have you seen actual lower wear due to (in part) the addition of this additive? Thanks.
I don't quite understand you?SonyAD said:In flat tappet engines with thin cams, unsupported camshaft bearings and high downward forces on the camshaft ...
It's a stress reliever. Radius and and chamfer corners have less stress than sharp ones.SonyAD said:...BTW, why do they camfer the edges of the cams. Isn't that making it easier for oil to escape from in front of it?
