79TA7.6
- Joined
- May 8, 2006
- TDI
- 2003 TDI Jetta, 2002 TDI Golf, 2005 TDI Golf
Finally got around to scanning the car.
18996- turbo boost control position sensor circuit. P2564- 000- signal too low.
01276- abs hydraulic pump (v64). 012- electrical fault in circuit
00591- seatbelt switch; driver (e24). 32-00 resistance too high
P.O. told me he took the seat belt latch out of this car to put in his 2 door as it had the same issue. Anyway to fix it, or am I looking for a new latch?
00931- locking module for central locking rear right (f223). 27-10 implausible signal intermittent.
This one is interesting as since we put a new battery in the fob the alarm has started going off at random times. I figured a bad door switch, but the fault says it is a bad rear door, which only the two passenger doors activate the interior lights when opened.
Off to look up the rest of the faults.
Edit: I should note that I scanned a couple nights ago and cleared the faults. Son has been driving this back and forth to school and has had no under boost issues. The above codes were from todays scan. They are persistent and do not go away. Receipts from P.O. says he replaced turbo a couple years ago.
