Thank you guys... It's nice to be appreciated. Huh AndyBees? Heh...
If the cam and lifters were bent up from a starter-speed hit, the likelihood of bending a valve or two is very good, but there should not be any piston or rod damage. Depending on the mileage, it probably is just our usual cylinder head reinstall kit and we can loan you TIMING BELT TOOLS! Along with some very good and helpful technical support by phone, email or text.
As for the original engine, I don't think I'd be in such a rush to move away from probably the best overall diesel engine VW ever has, or apparently, ever will make. To change out to the PD motor would be a mistake, in my opinion. On the other hand, we do have currently, a builder that is going to put an ALH into a BEW frame, which means a change of ECU and wiring harness, at least. But in my opinion, that change out would be an upgrade. Why? The ALH engine is easier to work on, has more mods to make it either more efficient and more powerful or BOTH. And overall, it is cheaper to maintain.
Don't fool with near perfection... In case you haven't seen it yet, there is a very detailed 'How To' for installing a timing belt for your ALH. Look for that on the Home page. I won't be around tomorrow, but if you are interested, we have done more than a few of these builds. Let me know if I can be of assistance.
