Abacus
That helpful B4 guy
What issues do you have, none I’ve ever reinstalled leak.What do you think about building a 1Z/AHU valve cover that won’t leak?
Good for you. Many many people have had issues with these valve covers leaking due to the poor design. I have installed at least 6 gaskets in two different engines and every single one has succumbed to some leak at some point.What issues do you have, none I’ve ever reinstalled leak.
I researched and made a jig to adjust the height of the valve cover at the 3 hold-down bolts so the perimeter seals before the bolt rubbers . Once this was done, my valve cover dosn't leak any more. This is where I read about it.Good for you. Many many people have had issues with these valve covers leaking due to the poor design. I have installed at least 6 gaskets in two different engines and every single one has succumbed to some leak at some point.
I'd like to, it would cost an astronomical amount of money though. LolWhat do you think about building a 1Z/AHU valve cover that won’t leak?
Can you make one out of Aluminum?Bumping to update the product catalog mildly. I still have numerous 1Z/AHU coolant flanges in stock and ready to ship for $225, as well as CCV plates, turbo inlet flanges, idler pulleys, and shift knobs. If you'd be interested in making a package deal for a discount, feel free to hit me up!
I'm cutting the price of idler pulleys to $125 shipped. I realize this is still quite an investment for something you can buy from Amazon for as cheap as $8, but these are now made completely from 420 stainless steel, with a brand new Timken 6303 bearing. I just removed an original aluminum prototype from my car that had 160k miles on it, and the bearing still feels like new. So suffice it to say, if you want to bulletproof your serpentine belt system, one of these will certainly do the trick.
I have and can! Same price.Can you make one out of Aluminum?
I can make that outside diameter to any size you like, easy as pie! I think the current dimensions are 2.25" OD and 2.02" ID. I can make the OD as small as you like, but probably not much bigger than 2.25. Seems like 2" OD with something like a 1.75" ID would work best for universal fitment, as I'd imagine 2" is a common size.Hi there! I saw your post for the turbo flanges on the Facebook VW B4 page.
I have a question for you. What do you think would be involved to make a flange that allows us to use a newer generation silicone turbo inlet pipe? Or is it possible that the flange you're currently making might work in that capacity.
The reason I'm asking is that I'm feeling a little cautious about this current design. You're the old plastic turbo inlet pipe is epoxied or glued to the inside diameter of the metal flange. There are parts of me that would much rather see a robust silicone hose clamped over the outside of a similar flange.
Any chance you'd make a custom one of these?Thanks for the link, that'll give me a better idea of which direction to go.
And sure enough!
I really love having it there. I can use whatever power outlet I want, and just flip a switch to turn on my accessories (GPS and Radar detector for now). I'll probably utilize another hole for my EVRY mod, and hopefully get my high-idle mod going as well.
Sure, that looks easy enough. In order to mount that plate to the center console I had to cut out quite a bit of the plastic where the ashtray used to be in order to clear all the wires. Obviously not a big issue if you don't plan on going back to stock. Then I just drilled a hole through the plastic in each corner for my screws to hold it in place.Any chance you'd make a custom one of these?
I'd love a cutout for a PanelPilot SGD-24M
The cutout size is here:
Would like to keep the 12V style port on the right or possibly swap it out for a panel mount USB power supply such as:
How is that panel mounted in the ashtray area?
Thank you!
Here is a custom-ordered coolant flange I just finished for a customer. It's made to fit an AHU engine block, accept a Mk1 Golf temperature sensor, and delete the coolant return line. It's going into a TDI Vanagon project.
Hey guys, I'm Charlie from Legacy Mold and Tool. We're a small machine/tool shop located in Bardstown, KY and have been in business since 1997. Since I've been with this company I've starting developing products to benefit my own vehicles - including my B4 Passat. I'm going to list a few things that I currently offer, and also discuss some things I'd like to bring to market later.
Updated 6/17/24
Products I currently offer:
Rebuilt O2A shift towers. I went through the entire assembly and replaced every plastic component with oil-infused bearing bronze, brass, or stainless, depending on its function. The relay arm is made from stainless and is fully-adjustable using the original captive bolt. The shift cable is held in place with a washer threaded onto the brass standoff to retain the cable's original position. You can find more photos and info here. Price is $250 plus a $50 core fee that will be returned to you when I receive your old shift tower.
These look FANTASTIC! But I also can't imagine how hot they'd get sitting in direct summer sunlight - I can already feel the blistering on the palm of my hand.Just a few photos of some cool shifters I've been messing with. From left to right: solid aluminum (6.5 ounces), Aluminum with brass insert (10.3 oz), Solid brass (20.3 oz), and Solid 420 Stainless (18.4 oz). I really like the solid stainless quite a bit, it's a nice feel especially when you take off the counterweight. But I've been running the brass inserted knob for a while and I think it's my new favorite. A little heavier for easier shifting but not super duper heavy. I know the B4 and B5 are cross-compatible, but I'll make one for any car.
They're not bad... But maybe you'd like a custom engraved pool ball better?These look FANTASTIC! But I also can't imagine how hot they'd get sitting in direct summer sunlight - I can already feel the blistering on the palm of my hand.![]()
Hey there, William! Got your message on the facebook page. Just get back to me on there whenever you get a chance and I'll ship that new flange out to you.So, it is indeed a small world!
I am the customer who had this done. I bought two if memory serves. I had the modified flange done for my mTDI (AHU) build to match the 1.6na temp sensor (M10x1.0).
I've rocked well over 250K miles on that flange with my build.
Nice to see you here Charlie, I should have guessed it!
There's a similar ALH 4Y flange in cast aluminum on Amazon and ECS Version too that I recently discovered. I'm not sure if it make sense making another version (but you maybe able to improve on them). Those two are for manual transmissions. However, the one (long skinny) ALH coolant flange you posted earlier in the thread, I haven't seen before. I'm not sure if that's for BEW+ newer setups or for the automatic.
Thanks again for making an awesome product! I've recommended it to many who ask me about it for their Vanagon swaps!
Cool knobs.These look FANTASTIC! But I also can't imagine how hot they'd get sitting in direct summer sunlight - I can already feel the blistering on the palm of my hand.![]()
Not with this material... with ABS possibly, but would still need testing for sure.The real question is whether that 3D print can stand up to being in the engine bay or bolted to the block without distorting?
