thechoochlyman
Hey guys, I'm Charlie from Legacy Mold and Tool. We're a small machine/tool shop located in Bardstown, KY and have been in business since 1997. Since I've been with this company I've starting developing products to benefit my own vehicles - including my B4 Passat. I'm going to list a few things that I currently offer, and also discuss some things I'd like to bring to market later.
Updated 8-27-24
Products I currently offer:
Rebuilt O2A shift towers. I went through the entire assembly and replaced every plastic component with oil-infused bearing bronze, brass, or stainless, depending on its function. The relay arm is made from stainless and is fully-adjustable using the original captive bolt. The shift cable is held in place with a washer threaded onto the brass standoff to retain the cable's original position. You can find more photos and info here. Price is $250 plus a $50 core fee that will be returned to you when I receive your old shift tower.
Turbo Inlet Flanges for the Baby Garrett turbo (and others). Can be machined with any preferred inlet diameter for welding in a tube, clamping on a silicone fernco, etc. $110 shipped in the US with new O ring and mounting bolts. Link to development thread with more info, and installation post.
420 Stainless Steel serpentine belt tensioners. $125 shipped, assembled with a brand new Timken bearing. Replaces VAG part number 028145278E.
Billet aluminum coolant flanges for the 1z/AHU engine. These replace the stock plastic part that tends to crack periodically - OEM part 028121132A. No more worries of reliability! Please PM me directly if you want to place an order. Price is currently $225 shipped for the kit. It will come with both hose barbs, bolts, and an O-ring. It will be delivered entirely assembled with liquid thread sealant on the hose barbs and ready for immediate installation.
More details can be found here.
Billet CCV drain plate for the 1Z/AHU/AFN engine. This will replace the stock plastic drain tube which tends to break periodically. It comes with an O-ring and two mounting bolts. Price is $35 shipped per item. I make two versions - one with a tapped hole (1/2-14 NPT), and one without. Just specify which one you need.
An installation example can be found here.
Aluminum window guide clips - $30 shipped each. Replace a cracked or broken plastic window guide on your factory window regulator with solid aluminum that won't crack! Will probably need a bit of final sanding on the edges to get a correct fit in your regulator rails.
Billet shift knobs - all types available for $75-150 shipped. Standard engraving is included (shift pattern, TDI/VW logo, etc.) Custom engraving is available, starting at $25. Currently the only vehicle I can immediately provide a shift knob for is a B4 or B5 Passat, or any vehicle with an M12x1.5 stick thread. If you want a shift knob for a different model, please PM me - I'm willing to develop products for any generation.
We are a fully-capable machine shop with:
Hurco CNC Mill
Prototrak CNC Lathe
Wire EDM
Sinker/Ram EDM
Surface Grinders
Heat Treating oven
We work with all kinds of materials, and are open to quote custom jobs. If you have a specific product you'd like to see us build in the future, please send me a PM for details.
Here's a link to our Facebook page: https://www.facebook.com/LegacyMoldandTool
Updated 8-27-24
Hurco CNC Mill
Prototrak CNC Lathe
Wire EDM
Sinker/Ram EDM
Surface Grinders
Heat Treating oven
