thanks to the OP for raising the question, timely for me.
Would the tune need any adjusting after swapping from a 10pm to an 11?
My ‘00 ALH (RC3+, PP520’s, PD150 manifold and intake pipe, Eurojet SMIC & larger pipes, Whitbread down pip, and just swapped back to a new Mahle vnt15) is still running the original 10mm ip. 320k on it, other than staking the pressure relief valve and replacing the end seal Oring the ip has worked just fine. Car still reliably returns 46-50 mpg, +4 or 5 more if I’m NOT driving it….
But as Oilhammer noted, 11’s can be acquired pretty easily. I see them often at a local junkyard with 100-150k on them for $500.
I‘m tempted to switch but would be reluctant if the tune needs adjustments that only RC can do. No issues with him in anyway, just need to establish some sort of limit on myself, lol
