LiquidBlackDZL
Decided to check my pads today and found them to be pretty thick. Bad news was I discovered the front passenger wheel to be wobbling. I took the wheel off, held the brake rotor with both hands on each side, shook it, and it wobbled. Did the same holding the top and bottom of the rotor and it wobbled.
The rotor was secure onto the hub, but I coudn't tell which point the wobble was coming from. When I wobble the rotor, the axle moves or shakes accordingly. So I don't know if the wobble is from a joint for the axle deeper into the engine bay, or at the joint right by the spindle, or if its just the wheel bearing. I didn't hear anything unusual. And I am familiar with the sound a bad cv joint makes when you turn the wheel while in motion, but I didn't hear that either. Thoughts?
