otty
- Joined
- Nov 7, 2010
- Location
- Revelstoke, BC
- TDI
- 2003 Passat W8=>TDI swap, 4Motion Wagon, PD130(AVF) 6Speed Manual, 2006 Jetta MKIV PD(BEW) Wagon 5Speed Manual
A warning to anyone considering a W8 front brake upgrade or a W8 swap:
I had to go to my local shop rather than my usual knowledgeable mechanic (3 hours hard mountain drive away) for a terrible noise from the front passenger side wheel. Turned out a brake pad (4/side) had delaminated and came loose. The shop also found one caliper piston was seized (if I believe him). He insisted on doing the rotors as well or "take it elsewhere". He wanted to replace the other caliper too as "preventative maintenance". I said no.
These brake pads and rotors were replaced 2 years and about 30k km ago probably with Napa garbage.
$1100 quote from the local shop for one caliper, both rotors, pads, brake fluid flush and labour (parts all Napa crap).
W8 oem part prices per side, front:
VW caliper - $800 or so
Lucas caliper - $550 or so
Good pads - $200 or so
Good rotors - $150 or so
These prices from my trusted shop.
Either way, these are bank breaking brakes! I always found my Jetta stopped just fine.
Think twice...
Think twice...
