gary9696
I have a 2010 Jetta TDI SportWagen is there a vent button? I don't see one.
Look at the left side of the filler neck. If there is a little button there that you can depress, then the mod has not been done (you can press this button with the side of the nozzle while fueling to get the same effect as the ventectomy).I need to figure out if my old '03 has had this done yet or not.
Mine took a lot of coaxing of the tab with a small screwdriver - I was also worried about breaking something before it finally popped out.I tried to remove my vent today but stopped for fear of breaking something. How hard is it supposed to be to pull the white plastic part out?
Thanks, I pump the diesel as slow as I can, then I give it a half dozen or so squirts til it's close to overflow, and I can pack 15 gallons in when I estimate I have about a half gallon left in the tank. Guess that's all I can do. I was hoping to be able to use the expansion tank.2006 and up cars are not ventable like the old cars are and don't need it. Trickle it in till full.
Just a quick addition to this since I finally did the ventectomy tonight on my 2003 TDI that I purchased new.Look at the left side of the filler neck. If there is a little button there that you can depress, then the mod has not been done (you can press this button with the side of the nozzle while fueling to get the same effect as the ventectomy).
Glad you got it out OK. Pushing on the button is definitely important - even with that I found it tricky to remove! For anyone else who hasn't done this yet, I personally found the directions here to be clearest (and if I can follow them, anyone can):I found that if you push on the white tab with a medium blade straight screwdriver, AND then push out on the "vent" in the filling tube, the assembly will push out. Trying to just push the white tab did not work well for me. It was the combination of the white tab and pushing the vent out.
Hey Gary. Seeing as these tanks are only suppose to hold 14.5, I'm not sure you can get 15.Thanks, I pump the diesel as slow as I can, then I give it a half dozen or so squirts til it's close to overflow, and I can pack 15 gallons in when I estimate I have about a half gallon left in the tank. Guess that's all I can do. I was hoping to be able to use the expansion tank.
Ok, so I printed out all the pics, and the tutorial that went with them (forgot from whose site, but thanks!), and I just can't seem to get the vent to budge. I push up on the white tab, and I think it might have moved a tiny bit, but I sure can't feel it moving.... I'm assuming that I have to push the vent towards the rear of the car to get it out, yes? Any other tricks? I have splashed some fuel treatment on there in order to wet it, as noted in another post here... But still no luck. I might try to put the fuel treatment in a small spray bottle for better aim.
My fear is that it will come part way out, and then I won't be able to get it back in or all the way out. Or, I'll get it out, but not be able to get it back in.
I bought this car in May of '04 and it has 80+K miles - could it have just been in there for too long??
Still trying.....![]()
Hi Guys, it's been a long time since your posts and I just tried it today on my 03 Golf. Had the same issue. I pushed too hard up on the tab and broke it too but it was still attached just no longer grabbing onto the edge. Pushed as hard as I could on the little button in the fuel neck but wouldn't budgei've tried to do this like 5 times now. damn white cylinder will not come out! i think i've broken the little tab by now even. i tried getting it wet with some additive and pushing really really hard with a screwdriver. thing ain't even budging the slightest bit. the little metal tab is all scratched and gouged up from my attempts. i'll probably try again this weekend. just wish i had more tools to make it more possible![]()
The pump will shut off regardless of the mod. The mod is so you can fill the fuel filler tube to the top without holding the vent open.I've looked around, but haven't found and answer.
I live in New Jersey and I think it's one of the last no self serve states around. Is there any risk of letting the attendant fill up my tank after a Ventectomy? Additional risks of the diesel splashing out before it clicks off and the like?
i don't live there. but from what others have said. you can fill your own tank when getting diesel in these states. if it was me i would check into that.I've looked around, but haven't found and answer.
I never let it get lower than when the light comes on for low fuel. With in 20 miles I always fill up and get about 15 plus gallons in it. I am getting only 48.5-51 in the summer and 44-45 in the winter. I am at High altitude also though. I fill it until there is fuel at the very top of the filler neck. Like I said I am in no hurry to fuel up. Gives me time to brag to others how good of MPG I get. I am at 240K miles now and have been filling this way since I bought the car with 86K.Lefty: If you haven't done this mod you are not filling the tank like a modded one. If I let my car get very low I can put over 16 gal.s in everytime. Before the mod was 14, I consistently get over 800 miles/tank with a 51 mpg. Granted if you hold the button you can but why not remove it and move on?
It's been my experience that it still automatically clicks off. The nozzle is in far past the point where the vent is, so the ventectomy doesn't prevent the back pressure that triggers the pump to stop.With the ventectomy will the fuel pump nozzle still automatically click off when the tank is full or do you have to keep an eye on it to make sure it does not over fill and spill out?
Yes. I'm not sure how the larger truck pumps would react; it's been a while since I used one.With the ventectomy will the fuel pump nozzle still automatically click off when the tank is full or do you have to keep an eye on it to make sure it does not over fill and spill out?
