PDJetta
- Joined
- Nov 6, 2003
- Location
- Northern Virginia
- TDI
- '04 Jetta GLS TDI Pumpe Duce Platinum Grey w/ Leather
This is the problem: If the valves contacted the pistons when the engine was run, either by not having the valve timing set properly (mark and pray method instead of using the proper timing belt tools) or if the tensioner was not tightened properly and the valve timing changed, there is a very high likelihood one of more valves got bent slightly when contacting the piston(s). If the valve timing is simply reset, or if the cylinder head is removed to inspect damage and all appears fine (and it usually will) and reinstalled, at some later time (perhaps 10,000 miles later) a valve head will separate from it's valve stem and this will completely total the engine (as in a non-repairable cylinder head and a hole through a piston) and may take out the turbocharger as well from metal chunks passing into the exhaust manifold. Once a valve is bent slightly, it lands on the valve seat cocked a little and over the millions of cycles of doing this the metal fatigues and the valve head separates from the stem and gets jammed by the piston as it nears TDC.
What needs to be done is the cylinder head removed and the valves removed and closely examined for straightness. You might as well have the head overhauled at the same time since it is off.
If the same shop removes the head they could cause all sorts of issues. They probably do not have these:
http://idparts.com/catalog/product_info.php?products_id=1262
Which means they can't properly install these:
http://idparts.com/catalog/product_info.php?products_id=449
They probably did not replace the engine mount bolts either.
The other thing is the shop proved their incompetence already and when removing a cylinder head if not careful, you can damage the engine and it may not be apparent right away. If the coolant is not drained from the the block (there is no drain for it, so either an oil cooler hose, thermostat, or water pump must be removed), coolant will flood the cylinders when the head is pulled. This is pretty damaging, especially if the oil is not changed and the engine started. Also, do you trust they will replace the cylinder head bolts, like they are supposed to?
Cut your losses while you can and after having one of the TDI Gurus fix it, attempt to recoup your damages from the first shop.
--Nate
--Nate
