Franko6
Pedro, thank you for the referral. I always appreciate people recommending my service.
The teeth being stripped off the belt, of course, is never a good thing. Usually it is age before mileage that causes the issue the further south or from our Mason/Dixon line the worse it gets.
but just because you have impact marks on the Pistons is not the end of the world. I call them “witness marks“ and it matters more what happened to the lifters.
We have received cylinder heads that had timing belt slips were all of the lifters are 100% good, and the camis in perfect shape. The cylinder head should never have come off.
The best advice I can give is to partially disassemble the cylinder head. Of course the timing belt must be removed, but we start by dropping the timing belt off for the cam sprocket, removing the cam caps and vacuum pump and even with the sprocket still attached, you can remove the cam and examine the lifters.
Once the cam is out of the way, any damage to lifter that is deeply bent downward is an engine speed strike, and the head must be removed. Also, any lifter that is bulged up as a starter speed hit. Either way, damage is either been done to the head of the valve or the stem of the valve. To return the engine to service without removing it bad valves is going to end up catastrophe, particularly when the exhaust valve snaps off, ruins your cylinder head, piston, rod and maybe even destroys the cylinder bore.
however, there is another strike which can be overlooked. I Collett a “incidental hit“. Remove each left her in order, and with a magnifying glass examine to see if the lifter has been fractured. A light fracture will not damage the valve, but if left in service, the lift her will work back-and-forth until the top of the lifter falls off, slides back in the lifter bore and the valve will cause a lot of distraction, definitely jump the belt and you’ll have a cylinder head now, that has to be removed.
Rather than completely removing the cylinder head, only to find out there is minimal damage; cam and lifters, you can save yourself a lot of trouble and time. But as bluntly as I can put it, if I have to remove the cam to see what is wrong with the lifters, so also, do you.
The point is, the lifters are the weak link in the chain and will damage whenever valve and piston contact is made. The very light strike may ruin the lifters, but we have seen the valves remain true. A badly damaged lifter equals a badly damaged valve.
I will be away from the business until next Thursday, February 3, if you need any additional support.
