dklopper163
I have a 2012 Jetta TDI Wagon and I was wondering how often do you need to add fuel additives and what are some good additives to use for it.
Okay thank you so much for your help I will look at those threads now.Search is your friend for a question before asking. Then if you have questions post them up. This has been covered over and over again here already so you should be able to find lots of info. Welcome to tdiclub! It is a wealth of info already.
If you are buying good fuel you probably don't need any. Many don't use an additive. Some do though if they think it needed. Cold weather is one good reason to stop freeze up of the fuel. I have been driving these since 2005 and tested quite a few of the popular ones in the past. Saw little to no difference and having to deal with the smelly stuff, which seems to get on everything, was a pain. Still have some sitting in the garage unused.
It is more of a personal choice if you aren't in a cold climate more often than not. Of all the threads here on it I haven't seen any need for one except in rare instances. I have never found water in my fuel and haven't had any issues other than the last cold snap we had it was frozen for a day or two. Drove the truck instead. If you want to use one just pick one of the major players and go with it. They all pretty much use and do the same thing.
That too is an opinion. Some say if you don't use it all the time it is worthless. Some use it every other tank or similar methods. Some use it when changing filters. Pick your poison, so to speak. Use it whenever you want to, all the time or when you decide. No matter which you pick it won't hurt the car if you follow the instructions for using it. If your fuel has any biodiesel in it you probably could just skip it. Some states mandate some percentage bio use. Biodiesel was shown to be one of the best lubricity additives in one unofficial test done long ago. This was small percentages of biodiesel. B2 biodiesel will do just fine as an additive.Okay do you know like when you should put the additive in? Because I saw on some forms they would say every other fill up, every fill or every oil change.
i personally like Liqui MolyLM2002 after having tried all of the above mentioned, you can use a can with every fill upI have a 2012 Jetta TDI Wagon and I was wondering how often do you need to add fuel additives and what are some good additives to use for it.
And then he proceeds to long-windedly non-answer the question with a bunch of opinions. AWESOME!Search is your friend for a question before asking...
Every post on this forum about fuel additives is an opinion. I at least provided him information on what was here already as well as my opinion. Evidently they found their answer that they were looking for and that was all they needed. I also was not harsh or critical in any way. Unlike your post, which provided no information at all and was just critical of me.And then he proceeds to long-windedly non-answer the question with a bunch of opinions. AWESOME!
It is true that VW doesn't recommend additives, but I'm pretty confident that the techs don't know what they're talking about. ULSD has far less lubricity than low sulphur diesel did, which is why a lubricity additive (or a couple percent of boidiesel) is good for the fuel system. It will extend pump life, not shorten it.I had my ‘12 Golf TDI in for some service at the dealership recently. I am on a first-name basis with many of the techs and asked this same question.
All of them said “no additives” to the fuel. They said it waters down the lubricating properties of the diesel fuel that the HPFP needs in order to work properly. I was told adding anything to the fuel can actually shorten the pump life.
FWIW.
That's good to hear. I'll look into those if I find it necessary to run.I just did a quick check on Stanadyne and Opti-Lube additives (the two we sell). Neither contain any alcohol.
That's odd to me because when mixed with diesel it will barely catch fire. I know that's not the same as combustion in a sealed chamber, but I still wouldn't expect an easier start.I did notice faster starts with Howe's diesel fuel additive in my TDI. I know skid loaders definitely benefit from using fuel additive when it gets bitter cold. I'm curious which fuel additive is the most cost effective these days.
