wjdell
D1 ESP will give great results - Amsoil DEO will give great results and so will S9000 CJ4 - albeit the S9000 is the closest in additve levels and vis to the VAG oils.
Maybe = lower soot, and lower soot = lower wear?SUNRG said:...when my UOA test results started coming back with far lower than average Fe wear rates many of the gurus here felt that my excellent results were in large part (if not completely) the result of my exclusive use of high quality virgin soy ASTM biodiesel which i picked up directly from the refinery. some dismissed my UOA results entirely as not being apple to apple comparable with everyone else's D2 fueled TDI UOA results...
How come now when I go to the Amsoil Online Product Application Guide the DEO no longer appears for my 2002 Golf. The recommendation is now for the Synthetic 5W-40 European Engine Oil (about the same price per quart).wjdell said:D1 ESP will give great results - Amsoil DEO will give great results and so will S9000 CJ4 - albeit the S9000 is the closest in additve levels and vis to the VAG oils.
Both DEO and AFL are 5w40. DEO is CJ-4, AFL is 505.01.Drivbiwire said:A 5w40 will outperform the 15w40 everytime (whether it's synthetic or not) in terms of flow capability ie a 5w vs 15w. Initial startup regardless of outside temperature will benefit the engine and turbo. In the TDI this will also provide improved protection to the turbo bearing and thrust bearing given the distance from the motor that the oil has to travel.
Amsoil is smart to only recomend the 5w40, this oil is very closely formulated for the TDI and is without a doubt a great oil for the VE engines.
DB
__. Is that "505.01 -- Approved and listed by VW" or "505.01 -- Marketing Speak"?????Bob_Fout said:Both DEO and AFL are 5w40. DEO is CJ-4, AFL is 505.01.
Irrelevant to the situation at hand.mrGutWrench said:__. Is that "505.01 -- Approved and listed by VW" or "505.01 -- Marketing Speak"?????
I'll bet its because the Euro oil more closely matches the OE specs (VW505.00) of the vehicle, instead of a generic standard that is more geared for HD diesel apps.tikal said:How come now when I go to the Amsoil Online Product Application Guide the DEO no longer appears for my 2002 Golf. The recommendation is now for the Synthetic 5W-40 European Engine Oil (about the same price per quart).
Any technical reason for this? I live in SE Texas with relatively mild winters. I would like to order soon for my next oil change.
Thanks in advance for any inputs.
Yes, it does appear that the DEO 5w40 performs better than the AFL 5w40.wjdell said:USE DEO - not AFL
Where is this info coming from?TornadoRed said:Yes, it does appear that the DEO 5w40 performs better than the AFL 5w40.
So if you have a VE engine (2003-and-earlier), use the DEO. If you have a PD engine, use a a motor oil not made by Amsoil.
i would imagine using b2-b11 would act as a "upper cylinder lubricant" and reduce ring wear and cylinder wall wear perhapstditom said:injection pump, yes. engine wear? not so sure. I thought there was actually a danger to the engine lube from high bd concentrations. Polymerization was the issue. The standing advice has been to lower the OCI for engines running bd > 30%, IIRC.
"We list the AFL over DEO because it is closer to the VolkswagenBob_Fout said:I'm going to e-mail them and ask why they've changed the recommendation twice now.
Cold vs. warm vs. hot.wjdell said:Bob Bob -- when I start my engine in Florida its takes 4 miles in summer and 5 to 6 miles in winter to come to temp. Oil does not work well below 180F. Anything below 190 F in a 06 PD is cold. I put a 180 watt block heater in and I now hit 190 in less than 2.5 miles.
Not revving the engine too high while it's cold is a good idea but it has nothing to do with additives and everything to do with viscosity. Cold oil is viscous and has a hard time flowing to where it needs to be. The anti-wear additives build up over time on metal surfaces due to heat and pressure and they don't go dormant when the oil cools, at least I never heard of such a thing.Bob_Fout said:Pete's famous driving style tips....When the temp needle comes off of cold (the three lines) you are free to rev the warm motor past 2500 RPM, the oil is sufficiently warm to allow that. Motor's not hot until you get to 190*F on the gauge (really 160*F and up). Supposedly the additives don't kick in until 160*F, so you need to get the oil up to and past that temp quicky?
how long does the block heater need to be powered before driving your TDI to achieve this?wjdell said:Bob Bob -- when I start my engine in Florida its takes 4 miles in summer and 5 to 6 miles in winter to come to temp. Oil does not work well below 180F. Anything below 190 F in a 06 PD is cold. I put a 180 watt block heater in and I now hit 190 in less than 2.5 miles.
TDI heater is 1000 watts, only one kW-hour. With a timer, an hour or two and everything would be toasty. And less risk of fire.wjdell said:The frost heater was intrusive and as well over 750 watts. The block heater strapped to the oil pan. At 180 watts the electric will be very little at night. My temp is above 100 F before I get on the hwy about 4/10 mile. Then 2 miles later I am at 190F. The heat from the oil pan rises up and warms the block. The heater was $ 25.88
