you can get rid of the snorkel "CAI" stuff altogether and eliminate and simplify. what i do is this:
-cut a larger hole in the bottom of the aribox - just enlarge the existing snorkel opening a bit - i enlarged mine so that it would fit the larger R32/vr6 CAI snorkel (but then i got rid of it).
- throw out the CAI ducting/snorkel stuff that goes around the battery and headlights
-done
ive monitored IATs with it setup like this and having the CAI stuff doesn't really reduce IATs much at all (at least not by any conclusively measurable amount) - except in conditions where it doesn't really matter much, like puttering around in hot weather traffic jams.
it gets enough cold air drafting up from down below the trans/wheel area. won't ever clog up with snow or have any chance of getting big gulps of water thrown in it.
you could use some foam/rags or something to block off a bit of "warm engine bay air" around the battery, but, doesn't seem to really have much affect i could measure.
your average big "CAI" cone filter in place of the stock airbox will definitely get higher IATs, but setup how i do it with the stock airbox, not at all really, not enough that you can really even measure.
