gshearer
Now that the skin on my knuckes has regrown (mostly ) - I hereby present my suggestions for how to replace an alternator in a 2003 New Beetle. Some of the work is done from above, but mostly from under the car...so wear old clothes, safety glasses and remember Edison's comment "...I am not discouraged because every wrong attempt discarded is another step forward".
First, thanks to several folks who have posted info & pics about how to do this on Jetta/Golf. This has been a big help, but the NB plumbing makes it a bit harder...well, maybe a lot harder! The VW dealers quoted me about $900 for a new alternator + labor! But, a $160 alternator & $30 belt from AutoZone + some knuckle hide did the job!l Here's my suggestions:
1 - Raise front end & SAFELY support w/ stands, ramps, etc.
2 - Remove two 10mm nuts & loosen third to remove engine cover.
3 - Disconnect negative cable from battery.
4 - Remove clamp from large air pipe next to fuel filter & push pipe toward rear for extra room to reach belt tensioner bolts.
5 - Remove two clamps supporting metal AC pipe to allow the compressor to be moved more (the rubber lines will let you move it quite a bit now).
6 - Remove belly pan & right side splash shield (spin off washers).
7 - Remove two 16 mm bolts holding AC compressor (reinstall torque 33 ft lb).
8 - Move compressor out of way toward rear (rubber hoses will flex).
9 - Remove three T25 screws holding electric fan & move out of way.
10 - Protect radiator fins with thin piece of plywood (use duct tape to hold).
11 - If accessory belt still on, use 16mm wrench to move tensioner toward rear & slip belt off compressor. CAREFUL - tensioner is strong & can pinch fingers!
12 - From top, remove three 13mm bolts (two short, 1 long) from belt tensioner & remove tensioner from bottom.
13 - Remove two 13mm bolts from alternator (reinstall torque 18 ft lb).
14 - Gently pry alternator downward & remove connector & power cable from rear of alternator.
15 - Move alternator toward left and remove downward by flexing radiator hose & moving AC compressor. This will take some wiggling to find the best angle. Remember this angle to help you reinstall later.
16 - To reinstall you'll probably have to move the threaded inserts on the alternator outward about 5mm or you'll have a very hard time fitting the alternator to the attach points. Move these by putting the bolt through a stack of sockets & tighten a few turns.
17 - Reinstall is basically reverse of above. Getting the alternator back up in place will require flexing the radiator hose & moving the compressor. Remember the angle of the alternator that let you remove it? The plywood will keep you from really bending the radiator fins. The belt routing diagram has been posted elsewhere on this site. A Goodyear "Gator" belt purchased from AutoZone was a bit short. However a Gates K060653 accessory belt fit great. Total time about 7 hours, including "thinking time". Now could probably finish in 3 hr.
Hope this helps,
Glen
Hope this helps,
Glen
