scooperhsd
Not just my 2000 New Beetle, but also our 2015 Golf . I remember the days when an ordinary joe could easily replace headlight bulbs, Now it means a trip to the shop...
Cadillacs with the starter under the intake manifold, the Chevy fuel spider under the intake, almost any heater core lol. I don't think it's that they don't talk to each other. I think they just don't care what happens after it is past warranty. If saving 5 cents on a unit means 8 hours extra work for you, that's just great by them.The amount of ill thought out designs that lend themselves to poor service leads me to believe that many people who come up with them are not on speaking terms with all of their coworkers. Nissan has some models that hide the fuse box in a place that requires the BATTERY be REMOVED for access. Always fun troubleshooting an electrical problem when you cannot have the car's battery hooked up and have to cobble together jumper wires to figure it out.
The Toyotas that stick the air pump under the intake with no filter so over time they just suck in whatever debris ends up down there and it tears up the impeller and sends the chunks into the overly complex and fragile air valve system resulting in a $3500 repair... "but it runs fine, the check engine light is just on".... yep.
Or the Subarus that have wheel bearings that go bad two years out of the factory yet somehow are already so rusted in place that you have to spend half a day beating the crap out of everything and replacing all kinds of extra parts because they won't come apart.
Or the Ford Transits that require control arm removal for ANYTHING associated with the weak transmission or exhaust system, and then you find out the threadlocker they use to put the bolts into the unibody is STRONGER than the metal they make the body from so it just tears it to pieces so you have to saw a hole in the rail and burn them out with a torch and then cut the control arms into little pieces to get it all apart (and these are on newish vehicles, none of them are more than five years old).
I could go on and on....
Are we talking sealed beam easy?Not just my 2000 New Beetle, but also our 2015 Golf . I remember the days when an ordinary joe could easily replace headlight bulbs, Now it means a trip to the shop...
We do a lot of ford 6.0,6.4,6.7 powerstroke work. It's not too hard to pull the cab once you're used to it. It takes about 2 hours, that's using a two post lift to pull it off. Just replaced a 6.7 engine that way.Starters under the intake don't really bother me (Toyota belt-driven V8s are like that, too). They generally are not that bad to change, really. And that is hardly the Northstar's biggest issue, LOL.
The early VR6 T'reg thermostat is a fun one: Step 1: REMOVE ENGINE. Taking the cab off of the Ford Super Duty trucks to service things on the engine is kind of extreme, too. It takes about five hours on the 6.4L just to get to a point you can actually SEE the engine. The front end assembly (complete with EIGHT radiators) has to be lifted off with the shop crane, it is so heavy.
Yeah, I'll deal with New Beetle headlights any day, all day.
Here is an Audi A8 getting its oil cooler seals replaced:
