Aquaticmind
- Joined
- Apr 17, 2009
- TDI
- 2003 Jetta Wagon
This brings up a different question. What adapters are made for the !.9L TDI to fit to other transmission/ transaxles?
Well, I only live in this world with the car I have, so I'm gonna make due. I have to tell every one of you that I really appreciate your opinions and advice, in the next 2 years I plan on having a lot of these modifications done.Scott02 said:The best bet in my opinion (though I realize your trying to start with a MK4 car)...
Would be to make a B4V Passat Wagon TDI Synchro...
then lift it a couple inches and run some aggressive tires.
I think that would be the best of almost all worlds.
If you stick with the first gen TTQ, it is nearly a bolt in deal. You will need some ECU help, though, since I am pretty sure it must talk to the rear diff, but if you go stand alone Haldex controller (again, easily available) the rest of the car looks, to your ECU, just like what it is: an A4 series New Beetle. You would lose EDL in the rear (but I think the aftermarket controllers CAN keep that). Again, go Wavetrac up front, Haldex/EDL rear and you have a REAL 4WD system.manual_tranny said:Well, I only live in this world with the car I have, so I'm gonna make due. I have to tell every one of you that I really appreciate your opinions and advice, in the next 2 years I plan on having a lot of these modifications done.
I have a new question that probably deserves to be put into the "conversions" topic. A friend of mine is driving a FWD Audi TT... and his 1.8 T engine is the same as VW...
IS MY ENGINE COMPATABLE WITH AWD TT??????
I think no matter what I do, I would be better off scrapping my body and parting out my car, while keeping my engine and necessary parts to have an AWD car that is capable of being lifted and has a 200hp TDi engine in it and gets 45mpg. NO?
So you are now saying you might keep your current engine and tranny to swap into a 4Motion Audi?manual_tranny said:Well, I only live in this world with the car I have, so I'm gonna make due. I have to tell every one of you that I really appreciate your opinions and advice, in the next 2 years I plan on having a lot of these modifications done.
I know I sound like an idiot asking how to do these mods. I'm not, really... I do know that a Jeep is always going to be better at off-road than MKIV.xiledsavior said:I hate to be with the crowd of nay sayers, and I'll gladly admit I'm wrong if/when you prove me wrong, but there's a right tool for the job of off-roading, and sadly a mk4 isn't it. If you're looking for milage and offroadability, many people have dropped a Cummins 4bt into jeeps where they then get ~30-35 mpg highway. The added benifit is that the 4bt is essentially a 6 cylinder with the front two cylinders cut off, so it runs on a far tougher drivetrain than an avg 4 cyl diesel. This also gives the jeep more torque, and is in general easier to mod for more peformance. It's well documented over at www.jeepforums.com and www.4btswaps.com. otherwise, going for an older VW would prob turn out better.
YES!! AWESOME!!! That was my first tire choice actually, until I found that I could get the AT Grabber in the 14" wheel size and have even more tire. The fact you can still get 50mpg with this combination just MADE MY DAY!!!!!rustwagen said:FWIW,
I've been running the metalnerd 2" lift/vr6 front spring/TT LCA bushings combo with the General Grabber at2 205/75/15 both on and off road for the past 2.5 years. The suspension is MUCH stiffer - closer to the feel of a TT. It does fine on the fire road/forest road trails out here in NM. The stiff suspension and rebound will effectively limit your speed offroad. I usually slow to a speed that will limit the brain rattle . If you're going to carry gear you'll need to find some rear wagon springs. The TDI and VR6 rear springs (the same, I believe) will not help with weight.
-Jason
2000 Baja Jetta
-And I still can get 50 mpg @ 65 on the freeway.
Here's one with my craptacular photo skills:manual_tranny said:YES!! AWESOME!!! That was my first tire choice actually, until I found that I could get the AT Grabber in the 14" wheel size and have even more tire. The fact you can still get 50mpg with this combination just MADE MY DAY!!!!!
I hope I can find a way to keep the clearance up and get my suspension a little softer for off-road, especially to "fix" the brain-rattle problem you describe. =)
Any pictures of your lifted Jetta with these tires? Please!? ;-)
2x. This is the first thing you should buy. Seriously the other things you can plan for, a busted oil pan is much harder to cope with.Don't skip the skid plate.
I see what you're saying, I guess I didn't read very closely originally, if you're just running up little logging roads and doing very light off-roading, I imagine the mk4 would work out fine. I do want to agree with every single person who's bumped the skid plate, armor will keep you running far longer then the highest lift you can find.manual_tranny said:I know I sound like an idiot asking how to do these mods. I'm not, really... I do know that a Jeep is always going to be better at off-road than MKIV.
I may sound really crazy, but 30-35mpg isn't close enough to 40-50 in my opinion. If anything, I'd rather have a 1.6TDI in a raised fwd chassis than the Cummins.
All I really want to be able to do is make it up and down some logging roads, and not get stuck in 8" snow. I used to have a fwd mk2 that was amazing in the snow even with crappy clearance... I believe my mk4 will be adequate for the kind of occational cautious adventuring I want to do.
If I get really desperate to do serious off-roading, I'll just put my dual-sport Chinese motorbike on a trailer and tow it.
The used VR6 springs I got did lift the front about an inch, but the rear springs were the same as my TDI springs (same paint marks). I'm not sure if any of the rear springs will lift the car. I lifted my wife's Jetta an inch in the rear just using a metalnerd-type spacer under the spring. Maybe the VR6 front springs and an inch spacer in the rear would work for you.darkhorse said:Jason, I love the look of you raised car. I'd like a little more ground clearance too. I thought the Metalnard kit would fill the bill for reasonable $$'s but I don't like the idea of the harsh ride. I'll probably go with springs alone. Are your vr6 springs taller than the Jetta wagon springs? TDI parts says the front are good for an inch , the rear 2.
I will be looking into this immediately.shizzler said:Will a 14" wheel clear Mk4 brakes?? I was under the impression that they didn't.
I doubt it. It is fairly close tolerances even on 15" wheels.shizzler said:Will a 14" wheel clear Mk4 brakes?? I was under the impression that they didn't.
coalminer16 said:Couple things. Get the Skid plate. Unless you want to be stranded 30miles away on a logging road. I don't care how much money you have or don't have. Get the skid plate. Don't get the lift till you get the skid plate so you have the money for the skid plate. The lift will help you from getting stuck in mud. The plate will help with getting stuck with a $6K engine bill to replace and getting stranded. Do you know how weak cast aluminum is.
I hear you about the cold! I'm sure some have over reacted but don't take it personally. They haven't been riding with you. I appreciate the thread as I'd like a little more clearance too. Still not sure what I'll do.manual_tranny said:
I think maybe you over-reacted. Heck, it's so cold out I don't even want to go driving.
