dieseljunkie
They are NLA from VW so must fab ur own. Any tips to make the job easier? The one that sprung a leak is the transverse one (L to R) on the rear.
That's the company I was trying to remember!i use cunifer line from fedhillusa.com
Thanks burpod, checked out their website. Using plumber's solder as a measuring tape is brilliant in their FAG! The lines look great also - so easy to bend! I will order a 25' roll of 3/16.i use cunifer line from fedhillusa.com good stuff, great prices... they also have all the fittings/etc you would want, and they are based in MA, so shipping around here is fast. and i have a couple basic bending tools from eastwood, works great
Wow, that is expensive. Maybe that's why I went with buying the roll and flaring kit last year.Just got back from Autozone and bought pre flared Cu Ni Fe alloy lines, very soft, easy to bend. expensive though. a 40 inch and a 50 inch piece is 17 and 20 dollars respectively.
We played with that stuff while at Autozone. They were nice enough to bring a roll out to demonstrate the loaner flaring tool. It is bendable by hand but no where as soft the the Cu Ni Fe line.Or,
Poly-Armour 25' for 24.99 from Autozone.
Poly-Armour bends by hand without kinking. Pull your old rusted line and use it as a template to make your new line.
Thhat particular Ebayer don't ship to the US though. There's another from the UK that will about $34 shipped to US.wow... that's an amazing price for being shipped from the UK! who would have thought lol...
That's a great price on Amazon for the Mastercool 7100 set. Are the adapters on the Mastercool self centering or threaded into the yoke ram screw like this OTC 4504?http://www.amazon.com/Mastercool-IS...90499&sr=8-3&keywords=mastercool+bubble+flare
that's the mastercool flaring tool i got, works great.
the nuts i used:
http://store.fedhillusa.com/14nutpack.aspx
Yeah I figured that I'd have to make more than one line and the pre flared line is never the right length so I have to cut and flare one end anyway (and too damn expensive).making your own brake lines is the best
fwiw, i never found it helpful to use an existing brake line to use as a prototype, other than to eyeball it
What's the purpose of those spring clips? My guess is they prevent movement of the hard line when braking so they don't continually flex and break over time? Did you put the line and hose through the hole in the chassis bracket or left them hanging? zip tied?I left those clips right off since they're a pain and I had to do my rear bushings once a year (but it's been fine since I put in the latest set). Speaking of which, your rear bushings aren't looking that great, those are crusty!
When redoing brake lines, it's often easier to not piecemeal them together.
Can you please describe your procedure to make your own line, getting the lengths and bends right to thread into the fittings and snap into the plastic line holders. I know that with steel (very stiff) brake lines, unless the line is bent so it gets a straight shot at the fitting, you can never get thread started. Is this problem eliminated with the Cunifer lines?making your own brake lines is the best
