Pulsing lights
wyopel
WA
1996 B4V-270k, 1998 Jetta-140k
ALL the lights in my B4 have started pulsing NOT flickering but pulsing between bright and not bright at a frequency of about twice per second. When I say all the lights I mean headlights, cluster lights, dome lights, everything.
All grounds are checked and clean, cluster was repaired (new caps) and is working fine. When the car is not running and lights are on with battery power only, they do not pulse. Alternator seems to be charging, but voltage coming to battery pulses between 14 and 14.9v.
I saw a couple of other threads describing something similar but no solutions. These symptoms make me think it is the alternator or a voltage regulator somewhere not working right.
What do you all think?
Vince Waldon
Edmonton AB Canada
Undervoltages can be a bunch of different things but overvoltages pretty much point straight to the regulator.
The voltage regulator is responsible for making sure the alternator puts out a smooth 14V... pulsing between 14 to almost 15 means it's time for a new one.
That said... worth pulling the regulator and examining the slip rings as well... might be worth replacing the alternator completely rather than going half-way with a new regulator if the rings are worn as well. Worn rings/brushes would cause voltage drops, not overages, but a new reg gets you 1/3 of the way to a new alternator, cost-wise., and I hate buying a new reg only to have to buy a whole alternator a few months down the road. :)
wyopel
WA
Thanks. That's what I figured. I have an spare alternator. I'll pop that on and see what happens.
Mozambiquer
Versailles Missouri
1998 VW Jetta TDI. 1982 VW Rabbit pickup, 2001 VW Jetta TDI
I second alternator problems. These bosch alternators often wear the slip rings out, and then it will pulse like that. If you need any parts, let me know, I can get them for you.
KLXD
Lompoc, CA
'98, '2 Jettas
Seems to me a rhythmic pulsing would be the regulator rather than the brushes but they are one assembly, no? So swap the assembly rather than the whole alternator to check.
When mine went bad I just got the light. Temporary fix was to pull on the brushes to stretch the preload out of the bent wires. Worked fin for a week or two while I ordered new brushes and slip ring. So maybe try that. Mine Had grooves almost 1/8" deep.
Mozambiquer
Versailles Missouri
Most often when i see the lights pulsing, it's either caused by a slip ring that's going out, or if its a failing rectifier which allows too much ripple voltage through.
Mozambiquer
Versailles Missouri
It appears, based on his measurements, that the pulses are over-voltages, not drop-outs. :)
I saw that now. I would check the ac ripple voltage next.
It is possibleto have a voltage regulator fail high, but that is not normal, and if it does, that is normally indicative of an aftermarket regulator.
Another possibility would be poor grounds causing the regulator to see low voltage and ramp up production.
wyopel
WA
Definitely over-voltages. Never dropping below 14v and not going over 15v. I swapped the alternator with a spare I had. The problem is gone. The bad one was not a Bosch. I'm not sure it is worth rebuilding.
Mozambiquer
Versailles Missouri
That's not surprising. I've seen so many aftermarket starters and alternators fail prematurely, and many that are bad out of the box. It's disgusting!
Abacus
That helpful B4 guy
Nobleboro, Maine
See signature for TDI's
That’s why I have them rebuilt now, too much new trash out there, even with the ‘lifetime’ guarantee.
