ALL the lights in my B4 have started pulsing NOT flickering but pulsing between bright and not bright at a frequency of about twice per second. When I say all the lights I mean headlights, cluster lights, dome lights, everything.
All grounds are checked and clean, cluster was repaired (new caps) and is working fine. When the car is not running and lights are on with battery power only, they do not pulse. Alternator seems to be charging, but voltage coming to battery pulses between 14 and 14.9v.
I saw a couple of other threads describing something similar but no solutions. These symptoms make me think it is the alternator or a voltage regulator somewhere not working right.
What do you all think?
