alphaseinor said:Excelent, I'll see if I can get up there to see your car!
Can you post MPG numbers later on your .658?
GdB did you try out auto mode? I know you dont like the cel but just cuious and what is your Injection Quantity running @?GdB said:I am running manual code with stock auto injectors and pump. But I do have a 14lb flywheel which made idle rough. All I had to do was adjust the idle up to max (945RPM?) and soft code IQ a bit to get it to the sweet spot. Then my idle smoothed out.
I have not got around yet to new injectors.
Alphaseinor...cruise works after unhooking trans cpu. now it's off to see oilhammer for a timing belt change.montyypythonss said:Alphasenior...Just did my 2nd fill up after the swap and got 45mpg. I can't keep my foot out of the accelerator. My 0-60 times have went from 12 sec with auto to around 10 sec with manual. Will check again once clutch has more miles on it. Been driving around 80mph. I think it would be better once I get my cruise working again. About that...I still am coded for auto but have not unhooked the trans cpu yet, is this why the cruise is not working? I assume it is because the car still thinks it is in park.
Alphaseinor I filled up my tank (3rd fillup) after my trip to st louis, 222 miles used 4 gal= 55.5 mpg, not sure how consistant this will be. I drove the speed limit the whole time.alphaseinor said:Excelent, I'll see if I can get up there to see your car!
MR. Frey,MR. Frey said:GdB did you try out auto mode? I know you dont like the cel but just cuious and what is your Injection Quantity running @?
on your shifting the fly wheel weight shouldnt make a differance I'll think on that one sounds like a pos tranny but maybe somthing else wil come to mind. is your clutch dragging do your master and slave jive? that would affect first and fifth.
A_Shifter said:Muah ha ha...Just bought a used O2J with OD and a Peloquin LSD (thanks DbLog)...getting ready to do this thing and have 2 questions about parts interchangeability (Yep, I used the search function with several wording combinations to no reasonably quick avail *smiley ducking behind brick wall not found in smiley opotions*).
So here they are: Found an 01 Golf parting out. 1. Hoping stuff like starter, flywheel, pedals & assoc brackets etc will go straight from the MkIV Golf into a MkIV Jetta. If nobody knows, I'll get part numbers and post results as I get them.
2. Anybody tried just using a whole engine harness assembly from a (manual) donor car instead of modifying the existing harness as discussed here?
Thanks everybody for a killer thread. I know I'll be spending a helluva lot more time here in the coming weeks as I line up the metaphorical ducks.
You can use harness from manual TDI but, as GdB said too much work and alot of things will needed to be add on. Just modify your old harness, quicker and easier. If you have time you can completely take whole wirining harness apart and remove unnessary wires out, then taped over with black friction tape. When done with swap and wiring your car will look like it came 5speed from factory, for average joi who don't whats supposed to be under hood.A_Shifter said:2. Anybody tried just using a whole engine harness assembly from a (manual) donor car instead of modifying the existing harness as discussed here?
i did try raising the number and that just made it worst but not sure if it was coded auto or manual when i did that so i will have to check that out this week sometime--otherwise it drives and works great.alphaseinor said:The programming is different between the automatic and manual codings in the ECU. you should try raising the adapted value instead of dropping it. I usually like mine above 2 and below 5... my personal value of choice for no smoke and lots of power is 4.0.
worst case you can do a hammer mod.
still no luck figuring this out yet. iq is in the 1.x still. weird thing is when i was done i checked his timing in the vagcom at around 82 so i thougt well i will get that set about in the 60's then the iq problem was noticed. i am not sure it was there when the timing was in the 80"skleinergti1 said:i did try raising the number and that just made it worst but not sure if it was coded auto or manual when i did that so i will have to check that out this week sometime--otherwise it drives and works great.
I got one from manual and one from auto, if you interested PM me.TN2002tdi said:I'm starting my swap next weekend and I think I have all of the parts with the exception of the metal flange/ gasket that goes between the engine and trans. Does any one have a spare one they would like to sell or maybe trade? I ended up with a few spares while junkyard digging.
Give me a call sometime after 3pm and I will try help you with the IQ & coding.kleinergti1 said:still no luck figuring this out yet. iq is in the 1.x still. weird thing is when i was done i checked his timing in the vagcom at around 82 so i thougt well i will get that set about in the 60's then the iq problem was noticed. i am not sure it was there when the timing was in the 80"s
any opions would be appreciated.
thanks
