alphaseinor
TDI Innovator, Gone but Not Forgotten
- Joined
- Jul 30, 2006
- Location
- Denton, TX
- TDI
- '03 Jetta TDI 780,000 miles (totaled out), 01 Audi TT 225 Quattro 230,000 Miles (runs great!), 00 Cabreetle Beetle dash, ALH & MK4 harness Swap
Project Kill Da Auto Wabbit!, Or how I learned to love the manual swap.
First post last updated 3/22/2010 - new part numbers for switches.
I'm working in a wiki version of this page... you can find it on Digi Sport Performance White Papers page.
Please read the entire thread (Currently as of 1-26-08 is 31 pages long...) before you decide to do this!!!
First This is a thread where I am going to go through what I did to swap out my automatic transmission to a manual 5 speed. If you want to do this, go ahead, this is just a reference to what I did, not the definative guide on the subject.
Second, GDB did a writeup on the wiring
in Word .doc format here
in .PDF format here
Here's what I got from the Junkyard
Transmission & mounts
Axels
Flywheel, Pressure Plate, Clutch, Misc.
Dust "tins" from engine assembly (there are two)
Clutch Pedal Assembly
Clutch Pedal Line
Shifter Box
Shifter Linkage
All Bolts and nuts, clips, brackets, etc...
All interior peices that touch the stick shift
Starter (looks identical... but is not)
Here are some common parts that you might not be able to find in the junkyard: Thanks to Rodrigues
Small Clip on Master cylinder - 7M0 721 431
O ring for master cylinder - 02F 141 143 A
350mm Hose to Hydraulic Tank - 857 721 453
Clutch pedal firewall gasket - 1j1 721 410
3 M8 Nuts that hold clutch pedal in N - 902 264 03
Transmission dust cover plate (manual) 06a 103 645 m
Engine dust cover plate (manual) 06a 103 645
Axle Bolts x12 (ask the dealer)
Transmission bolts there's four of them, two different sizes (ask the dealer)
53 relay (very common in VW's... just look around)
a bunch of butt connectors
Here's some part numbers (still need to be verified)
AXLES
1 Axle Left 1J0 407 271 H
1 Axle Right 1J0 407 452 X
8 Bolts 893 407 237
6 Spacer plates 1J0 407 357 A
2 Locking Nuts N 905 876 02
TRANSMISSION
1 EGR coded trans 02J300047M
TRANSMISSION FLUID
2.0 Liters G 052726A2
TRANSMISSION BOLTS
1 Top Bolt Rear N 10337803
1 Top Bolt Front N 90701604
3 Oil Pan Bolt N 90870401
1 Bottom Rear Bolt N 10337803
2 Starter Bolt N 90766202
TRANSMISSION LEVER
1 Shifter Assembly
1 Knob Assembly 1J0711113BB
2 Lock Washer 1J0711280B
2 Bushing for up down 1J0711067L
CLUTCH PEDAL
1 Clutch Pedal Assembly
1 Bracket 1J1721379B
1 Bracket Cruise unknown
1 Clutch Hose 1J1721465AL
1 Slave Cylinder 1J0721261H
2 Salve cyl bolts N 0103324
5 clutch pedal bolts N 90226403
CLUTCH SHEILD
Main Part 06A103645
Axle releif 068103645M
Bolt N 0102085
spring washer N 0122265
STARTER
1 Bosch 02A911024DX
CLUTCH
1 SMF Valeo G60 VR6 Kit
includes all bolts, flywheel pressure plate, cltutch, throwout bearing
ELECTRICAL
1 '53' relay
8 pink crimps
Clutch Switch Cruise 1J0 927 189 E
Switch Cruise Connector 6N0 972 704 D
Clutch Switch Starter 1J0 927 189 C
Switch Start Connector 1J0 972 702
Reverse switch 02K 945 415 C
Rev switch connector 1J0 973 702
SPECIAL PARTS
1 modified bracket
1 short shifter
paper clip, or terminal tool (for the wiring)
You need a Vag-com, triple square bits, an engine support ( www.northerntool.com has a nice one for $60), transmission jack (you can use a come along, or a couple of ratchet straps), clutch alignment tool (some of the clutch kits come with them), sockets, torque wrench, lots o misc tools... etc ad nausium... You may have to dig into the relay, and I'll post photos on that later in March 2007...
Photos of stuff
Here's what I got for my clutch
G60 VR6 Flywheel Non-lightened for best gas mileage on the highway, besides, I don't race autocross in my golf.
Stock G60 clutch (should hold about 250lb ft of torque)
Stock G60 Pressure Plate
Misc Bolts stuff
Trans Mount Bolts (they are stretch bolts, marked with an X)
Axle Bolts for a Manual transmission
If you want something that will hold more torque think about a dual diaphragm clutch like the one that BleachedBora sells at www.boraparts.com
Here's what I paid for everything
$1200 for anything I wanted from the TDI I ripped everything out of, with the exception of the motor, and interior. They didn't let me take the PCM (ECU, computer, whatever we call it) however you will just need to go into engine--> coding --> change the number from 2 to 1 leaving the leading 0's intact (see www.ross-tech.com for the exact information).
$400 for the G60 clutch and misc bolts... you can probably just use the clutch that came with the other TDI, I would personally use a new one www.boraparts.com www.tdiparts.com www.dieselgeek.com are all good places to look for parts.
$300 for the short shifter from www.dieselgeek.com which is needed for clearing the stock power steering line. if you decide not to use the automatic version of the power steering line, this is not covered (yet) in this document.
There is tax, shipping, misc other things like fluids, bolts, and other misc things that go into this type of thing (think about $100-$200). There will be some modification to the wiring harness, so if you are not ready to solder or crimp something, then you should probably look into trading your Auto TDI for a Manual TDI.
That's $2100 for the swap, you can add about $1000-1200 in labor if someone is doing this for you (I charge $1200 + parts to do this, and it takes a "three day weekend")
As you can see there is plenty of room for the clutch pedal, and you don't need to have the shortened brake pedal like in the MKIII cars
The photo of the grommet where the clutch pedal hydraulic lines shows that at least with my car, it should be relatively easy for everything to get done.
This is where the master brake cylinder will need to be cut on the reservoir to connect the clutch. On my car, it's just nip, and connect.
Step 1: I removed the air box, and placed a paper towel into the turbo inlet hose. A tip on removing the air box is to take the MAF Connector, vaccum hose, then remove the top of the air box. there are two (10mm wrench) bolts holding the bottom of the air box on the chassis, you can get at them with an extension. then you should be able to see the transmission much better.
Step 2: Remove the Battery, and battery tray.
in .PDF format here
Axels
Clutch Pedal Line
Shifter Box
Shifter Linkage
AXLES
8 Bolts 893 407 237
TRANSMISSION
TRANSMISSION FLUID
TRANSMISSION BOLTS
TRANSMISSION LEVER
1 Shifter Assembly
CLUTCH PEDAL
CLUTCH SHEILD
Main Part 06A103645
Bolt N 0102085
STARTER
1 Bosch 02A911024DX
CLUTCH
ELECTRICAL
1 '53' relay
8 pink crimps
SPECIAL PARTS
1 modified bracket
1 short shifter
Photos of stuff
Misc Bolts stuff
