To those that did the hard work in figuring out how to do this swap - Thank you.
I hope someone here can help me. I have recently completed the auto to 6 speed manual swap on an 01 jetta ALH. My only issue now is that although I have recoded the ECM, I am getting a CEL, with the only codes saying that the modules cannot find the TCM. It is kind of acting like although the ECM says it is coded to a manual (00002), it is acting like it is still coded to an auto (00001) - with the codes that are showing and the fact that my engine did not run any differently - no rough running or mpg increase or need to adjust the IQ. Additionally, the cruise cancel switch on the clutch pedal does not work, but the one on the brake does. I will post the vag-com output below. I have followed different variations of the methods of recoding the ECM which have been posted in this thread, to no avail.
Monday,19,December,2022,17:54:42:30934
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
Mileage: 450720km-280064mi Repair Order:
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
Mileage: 450720km-280064miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 CP
Component: 1,9l R4 EDC G030SG 2839
Coding: 00002
Shop #: WSC 12345
VCID: 6099AC74F3542E6B8B2-4B3C
1 Fault Found:
18034 - Powertrain Data Bus
P1626 - 35-00 - Missing Message from TCU
Readiness: 1 1 0 1 1
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 12345 111 45799
VCID: 2A0D0E5CC0E8A43B956-5184
1 Fault Found:
01315 - Transmission Control Module
004 - No Signal/Communication
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 04 AIRBAG VW6 0202 0004
Coding: 12340
Shop #: WSC 00066
VCID: 3A2D3E1C354814BBE56-4B5C
No fault code found.
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 905 M
Component: A4-KOMBIINSTR. VDO V53
Coding: 07234
Shop #: WSC 12345
VCID: 313F1930E83ED7E354C-5184
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0A3472737
IMMO-IDENTNR: VWZ7Z0A3472737
1 Fault Found:
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00007
Shop #: WSC 00066
VCID: 70B9DC3423B49EEB1B2-5184
1 Fault Found:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
VCID: 06559AEC3130A05BD1E-4B1E
Subsystem 1 - Part No: 1J1959801C
Component: 61 Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 61 Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 61 Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 61 Tõrsteuerger. HR0002r
Address 56: Radio Labels: 1J0-035-18x-56.clb
Part No: 1JM 035 157 A
Component: Radio DE2 0005
Coding: 02042
Shop #: WSC 00066
VCID: 3E25320C2960389BD9E-51F2
End----------(Elapsed Time: 05:13, VBatt start/end: 13.5V/13.7V)---------
