Yeah, the Jettas got the fragile "looks cool but if your passenger isn't careful they break" dash vents, while the Golf just got "regular and gets the job done without breaking" dash vents.
They are fragile but not too bad. Not sure how people are breaking them unless they are taking them in/out a lot. The mechanism for functionality is pretty simple. That being said, I pulled a couple sets from a junkyard. There were only a few vents that weren't trashed so I don't know what people are doing. I like the flat style better aesthetically but yeah the original ones are probably more robustYeah, the Jettas got the fragile "looks cool but if your passenger isn't careful they break" dash vents, while the Golf just got "regular and gets the job done without breaking" dash vents.
I did that on both the Jetta Wagon and the Jetta Ute. I hate Jetta dash vents.And change the dash vents, LOL.
Have you guys never had clueless passengers before? Trying to adjust the vents by forcing the actual fins... Trying to open the door by picking at the door lock knob... Come to think of it, I'm lucky no one ever tried yanking the glove box open.No idea what people do, either, but I have seen LOTS of them broken over the years. Passats, too, which have the same deal. The Golf ones don't seem to ever break. However, it may just be that nobody is messing with them, because they are not temped by the "ooh, isn't this neat!" factor.
Honestly, I think all mk4's are 2 seaters on long trips. In fact, I have the rear seat cushions permanently removed on my 2002, and soon to be on my 2000, because my dog is usually in the back, along with whatever cargo I'm carrying.Jetta is not a good car for an adult to spend a many mile trip in the back seat. I don't know if the Golf or Beetle are any better. Can't lay down in any comfort. They are pretty much a 2 seater car except for short trips.
You need one built like that Audi A3 that showed up a while ago. 2dr on drivers side, 4dr on passenger side. Modern AMC pacer-ish.The pros/cons of the 2dr vs. 4dr Golf is always on my mind, having both.
4dr pros: shorter doors means less room needed when parked close, and it is far easier (obviously) to get humans in/out of the back seat, but also far easier to get a bag or item in/out with the rear doors. It also holds the shoulder belt slightly further off my chest due to the B-pillar being closer to the front of the car, and it is easier to reach back and grab said belt to buckle it. The body also seems to be less "flexy" over uneven surfaces, and doesn't creak at the door attachment points in the cold like the 2dr can (despite the 2drs having an extra alignment tab in the door bottom). The front windows also don't wear the slides and "rack" as much over time, and I suppose the crappy VAG power window regs would be less stressed, too. Also, you can crack the driver door window an inch, and the right rear window an inch, and have awesome ventilation with little wind noise (farts get whirlwinded right out of the car at faster than the speed of smell.... which is important).
4dr con: (singular, only one), the B-pillar placement means I have a blockage of sideview directly to my left.
2dr pros: better side view to the left, as well as a nicer "window down arm out" in nice weather cruising ability. Easier to get in and out of, as I am not wrapping myself past the B-pillar. Subjective, but the 2dr does look a bit sportier although they both have the same silhouette at the roofline. Less likely to be asked to drive a group of people anywhere
2dr con: seat belt is hard to reach, and it constantly pulls on my shoulder. Door hinges, window tracks, etc. all seem to be taxed with the extra weight and are not build with any extra robustness. More body flex, noticed more in the cold. Door length means parking it tight spaces can be a pain, and if the wind catches that door, watch out! Back seat access limited, and requires front person to not be there. Not as much ventilation, so fart mitigation is hindered.
Hah, some days I wish it weren't so dang long! Would make fitting into some very interesting cars a lot easier... or even some normal cars.Leave it to Matt to brag again about his long torso....
I feel your pain. I'm 6'4", but legroom isn't a problem on these cars. Amazingly, I fit into the Golf good, despite maybe having 1-2" tops of clearance if I sit up straight. Not a problem in the New Beetle, but there are so many reasons that will never be a desired body style.Hah, some days I wish it weren't so dang long! Would make fitting into some very interesting cars a lot easier... or even some normal cars.
Such poetic prose.farts get whirlwinded right out of the car at faster than the speed of smell....
