That leak looks like it's coming from the EGR cooler. On both my coolers the stainless line screwed into them was loose. Other than that, the turbo drain or feed could be leaking.Oh man I hope someone knows this. The exact same part on my Jetta is coated in oil and cant see anywhere it could be coming from. I've searched several diagrams just to find out what that thing is with no luck, hopefully it'll get solved for the both of us.
I'll keep you updated if I find anything. However, we are just starting a cross-country move and it'll be 6 weeks min before I can even look into this.Oh man I hope someone knows this. The exact same part on my Jetta is coated in oil and cant see anywhere it could be coming from. I've searched several diagrams just to find out what that thing is with no luck, hopefully it'll get solved for the both of us.
Thanks! I will see if I can find some diagrams to locate those. Probably nearly inaccessible??That leak looks like it's coming from the EGR cooler. On both my coolers the stainless line screwed into them was loose. Other than that, the turbo drain or feed could be leaking.
Yeah it's behind the dpf. You might be able to see it.I'll keep you updated if I find anything. However, we are just starting a cross-country move and it'll be 6 weeks min before I can even look into this.
@calimustang - I am confused by your comment. The oil still collects there, but I cannot find it's source. The top picture in post 16 is the same EGR unit, but just looking up from the bottom. And I had already cleaned it off. Bet there is some drops forming this am.
look at what he (oilhammer) said.That is the low pressure EGR valve. That is not what is leaking oil, it is coming from higher up, from the breather or the valve cover.
I combed all over that area, best I could. There is just a mess of tubing and it's impossible to see past them. I am 95% certain it is not the valve cover gasket. I was able to see the rear of it in it's entirety using the mirror while the DPF was out. I'll admit that I don't know where the breather is, but from my other automotive knowledge, this always seems to be in the valve cover somewhere. It it were leaking, there would be evidence of it on the valve cover gasket.
Perhaps the next oil change, I will borrow and video scope and see if I can snake it up in there and have a better peek.
I haven’t been able to find the part number yet- but I was wrong in my last post. The Pcv/Ccv diaphragm can be taken out and replaced!Worth a look. Intake isn't hard to pull.
To attach pictures, I have a google photos account that backs up all my phone's photos. From there I have a shared album dedicated to the Jetta that I then copy the address for and paste that into the pic icon above. ...in a nutshell
What stage tune did you go with? I am pretty convinced that the increased boost just sucks oil by the ccv system… or the internal ccv baffling system is old and failed- not worth $300 and the trouble of replacing the valve cover to rule it out.Did the CCV fix the leak? I have a 2013 Sportwagen CJAA with the exact same leak. I made a shield to keep it from dripping on the CV shaft a spraying around in hopes I could see where it is coming from but no luck. The leak started shortly after doing a DPF delete not sure if they are related or not. Before the leak the car was using a little less than a quart every 5K miles. Now a quart every 1K to 1.5K.
I have the same exact leak on a Malone stg2 Audi a3. Interested to see your final solution.What stage tune did you go with? I am pretty convinced that the increased boost just sucks oil by the ccv system… or the internal ccv baffling system is old and failed- not worth $300 and the trouble of replacing the valve cover to rule it out.
I went from this leak with a stage two, then threw a 170 hybrid in…. Choked the ccv tube down to about a 1/4” diameter and it no longer leaks… working on a catch can setup now for a proper fix. Probably not the greatest- but I figured that if I vent to atmosphere the system was designed to run under vacuum…. My choking it down and under vacuum would be better than no vacuum . Have made worse decisions in life. Catch can will be the better rout.
Commutes 180 miles a day for work just fine…
The oil at 27psi that comes through the ccv is pretty ridiculous… so lots of other guys have put bigger turbos, with more boost and may not have this issue?? Would probably lean to I have a ccv failure/damage with some part of the baffle… but again. For me it isn’t worth it.
