FTS is working!
autoscan:
autoscan:
Code:
Friday,05,April,2024,17:02:35:65121
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.2.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240306 DS355.0
www.Ross-Tech.com
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 13 15 16 17 19 1C 25 37 3C 3D 42 44 46 4F 52
56 5C 5F 62 72 77
VIN: 3VWPL7AJ9DM694726 Mileage: 387710km-240911miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0001
3C-Lane Change -- Status: Cannot be reached 1100
3D-Special Function -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
5C-Lane Maintain. -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Not registered 0011
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Not registered 0011
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI F000AG 9983
Revision: 12H15--- Serial number:
Coding: 0050078
Shop #: WSC 66565 257 00032
VCID: 3039020CD62CB59AFB3-8064
VINID: 0E69E070745A2547462441C2181338AF46
No fault code found.
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9430
Revision: 05651213 Serial number: 00001303061311
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 1471AE9C427469BAFFB-8040
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492B80FE881206E6921F0142873200
Shop #: WSC 12345 123 61029
VCID: 7DA7EB385DFE88F2205-8028
2 Faults Found:
01309 - Power Steering Control Module (J500)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Time Indication: 0
Date: 2018.08.27
Time: 17:00:04
Freeze Frame:
Count: 0
Count: 14
Count: 4096
Count: 8212
Count: 44800
Count: 1
Count: 256
Count: 0
03197 - StopPing Distance Reduction 2 in ADR Control Module (J428)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Time Indication: 0
Date: 2018.08.27
Time: 17:00:04
Freeze Frame:
Count: 0
Count: 14
Count: 4096
Count: 8244
Count: 44800
Count: 1
Count: 256
Count: 0
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001019
Coding: 0010002002
Shop #: WSC 00066 000 00118
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 7BA3E520436A86C21E1-802E
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 3068
Revision: BG021001
Coding: 2F380E3C802F3EC4008800C1700000C44F000086535D05F0648020200040
VCID: 392F3F28095674D24CD-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 10061 26 0512
Coding: 009795
2 Faults Found:
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Time Indication: 0
Date: 2018.08.27
Time: 17:01:14
Freeze Frame:
Term 15 On
Voltage: 12.45 V
ON
ON
OFF
OFF
OFF
02395 - Parking Light Front Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Time Indication: 0
Date: 2018.08.27
Time: 17:01:14
Freeze Frame:
Term 15 On
Voltage: 12.45 V
ON
ON
OFF
OFF
OFF
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 01121577090711
Coding: 00001000FE073B
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 3635341438C89BAAA1F-8062
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R01Z2X/ Dataset Number: 1KM003v__B_ 0047
Coding: 00004E42
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C21263C06E441FA57B-8068
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00007AHJ00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME406F0179ZZZZ
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME59360179ZZZY
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME205F4A2FZZZY
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME6134482FZZZP
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME7F042C2FZZZX
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME180A2C2FZZZR
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 1K5 953 521 CR HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20180114000228
Coding: 1202040000
Shop #: WSC 00081 790 00126
ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 7F5B113057729AE2329-802A
Multifunction steering wheel control module:
1 Fault Found:
365080 - Controls in Steering Wheel
U108E 00 [00001001] - No Communications
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Date: 2024.04.05
Time: 17:00:04
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K7 920 880 A HW: 5K7 920 880 A
Component: KOMBI H05 0407
Serial number: 00000000000000
Coding: 270D01
Shop #: WSC 01383 790 00017
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 33330D002BBA8E82861-8066
2 Faults Found:
13648640 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Steuergerät für LaneDepartureWarning: keine Kommunikation]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 387717 km
Date: 2024.04.05
Time: 17:01:14
13649152 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Steuergerät für Spurwechselassistent: keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Date: 2024.04.05
Time: 17:00:04
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BR HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1708
Revision: H51 Serial number: 18011400F13614
Coding: 352002
Shop #: WSC 12345 123 12345
VCID: 015F97C82106EC1244D-8054
3 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 387717 km
Time Indication: 0
Date: 2018.08.27
Time: 17:00:05
02849 - Control Module for Lane Change Assistance (J769)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Time Indication: 0
Date: 2018.08.27
Time: 17:00:05
02797 - Control Module for Directional Stabilization Assistance (J759)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Time Indication: 0
Date: 2018.08.27
Time: 17:00:05
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RNFG307
Coding: 0000002
VCID: 7EA5EC345CF893EA39F-802A
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0407
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: 6A8DD0643CF00F4AF57-803E
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change
Cannot be reached
Address 3D: Special Function (J052X) Labels:. User\1K0-953-569-G.lbl
Part No SW: 1K0 953 569 G HW: MFL PCB
Component: MFL W HEATER 2.0 1.3
Revision: H2.0 1.3 Serial number: Belle
Coding: 8333000000002D0700
Shop #: WSC 04233 001 12320
VCID: 38293A2C325C6DDAB33-806C
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0006881200
Coding: 0004B5
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BE385A0E3AA66C27E1-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1509
Serial number: 00000007899023
Coding: 000490
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 243 3501
Revision: 00H22000
Shop #: WSC 77101 662 370085
VCID: 392F3F28055674D24CD-806C
1 Fault Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 387717 km
Time Indication: 0
Date: 2018.08.27
Time: 17:01:15
Freeze Frame:
Voltage: 12.50 V
DD
Temperature: 30.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AJ
Component: EZE_2 H51 1708
Coding: 00000000
VCID: 6FBBC1700792EA62A29-803A
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Time Indication: 0
Date: 2018.08.27
Time: 17:00:04
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0006836290
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CE186BCE6A461FA77B-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1509
Serial number: 00000007812738
Coding: 000490
Address 56: Radio
Cannot be reached
Address 5C: Lane Maintain.
Cannot be reached
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 684 D HW: 5C0 035 684 B
Component: MU-S-NS-US H30 0478
Serial number: VWZAZ2S0304048 Dataset Number: V03935239NF 0001
Coding: 02630102AA00000050220001001808009F0102C400200105C6
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 2615E454E868EB2A11F-8072
Data carrier:
Subsystem 1 - Part No SW: 5NA 919 866 AQ HW: -----------
Component: NAR 2020/21 --- 1410
Serial number: --------------------
5 Faults Found:
15360256 - Component Protection
U1101 00 [00001001] - Active
[Anti-theft protection - component protection active (0xEA6100)]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Date: 2024.04.05
Time: 17:00:04
Voltage terminal 30: 12.3 V
2565 - GPS Antenna
B1054 13 [00001001] - Open Circuit
[GPS aerial - open circuit]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Date: 2024.04.05
Time: 17:00:11
7178 - Function Restricted due to Missing Message(s)
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Date: 2024.04.05
Time: 17:00:06
BAP-BAP_Function_ID: 02
7194 - Function Restricted due to Missing Message(s)
[Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Date: 2024.04.05
Time: 17:00:06
7223 - Function Restricted due to Missing Message(s)
[ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Date: 2024.04.05
Time: 17:00:07
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664706013 Dataset Number: 7P6035730K 0001
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A2D20240CD07FCA457-806E
2 Faults Found:
9457427 - Left audio channel for speech/telephone
B104F 13 [00001001] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Date: 2024.04.05
Time: 17:00:04
9457171 - Right audio channel for speech/telephone
B104E 13 [00001001] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 151
Mileage: 387717 km
Date: 2024.04.05
Time: 17:00:04
End----------(Elapsed Time: 01:32, VBatt start/end: 12.5V/12.5V)-----------
