mrfiat
- Joined
- Mar 24, 2008
- Location
- Los Ranchos, NM
- TDI
- 2003 Jetta TDI (Reflex Silver) , 2003 Jetta TDI Wagon (Black)
Hello,
My 2003 Jetta sedan is making a ticking/licking noise when running and my research indicates that it fail sometime in the near future. I have at 10 mm pump on the car now and a KermaTDI tune on it (with bigger injectors). I have a 11 mm pump that I pulled from the junkyard a few years back that I plan to replace it with. I have all the openings sealed on the 11 mm pump.
1. Will the 11 mm pump cause any issues with the KermaTDI tune? I figured it will just have more power, but not sure.
2. I have a pump seal kit that I plan to install tomorrow. Which if any seals should I replace? No way to know if the pump leaks
since it has been sitting for so long.
Thanks!
Thanks!
