CKRATDI
- Joined
- Jan 19, 2022
- Location
- Kansas
- TDI
- 2014 B7 Passat TDI CKRA Se limited Edition Sport- DSG-full deletes
14 b7 passat nms TDI. Not sure what the issue is, I think the wastegate actuator is stuck open possibly. Was accelerating, let off throttle, heard noise sounding like a boost hose came off or something but all the connections are fine. Instead of psi building up on the boost gauge it builds negative boost or vacuum on the boost gauge, it has much less power but seems to run fine engine wise. The turbo seems to not be working, I can't hear it spool at all, and it just sounds boggy and surgy when I Rev the engine. Any help would be great, I don't know if I can fix my current wastegate electronic actuator or if I need to replace the whole thing and I've never replaced one or adjusted one. Please help
