Hey all. So to make it short and sweet, my 03 alh jetta wagon 5 speed was running beautifully. Well I hit a large pot hole a little too spiritedly and afterwards, the car now has a vibration. It does it idling regardless of clutch pressed or not. It does it driving, pretty consistently. The only times it doesn't is when actually moving in reverse, or hitting the very small bumps in the road, it stops for a very split second. The noise follows engine rpm. Could this be a clutch issue? I believe the clutch was maybe just starting to slip before this happen, but only under heavy acceleration. All I have are slightly larger injectors and a mild kerma tune. Everything else is stock. Would greatly appreciate the help
