Andyinchville1
HI All,
As a kid I always wanted a Z but time just passed and..... well here I am !
Anyways, I recently stumbled across a 1981 Z28 in pretty good shape except for a blown engine and missing tranny so I am thinking perfect TDI swap !
I was recently thinking I would like a Forester TDI conversion for wagon practicality (cargo space since I am a courier) , AWD and fuel economy BUT the allure of a childhood fantasy (and I suppose many adults still lust after the chevy Z) in an AWD Diesel form may be too much to resist!.... PLUS the 2 trunks my offset the small wagon cargo capacity?
Anyways, my thought was to locate the TDI engine / 5 speed longitudinally in the rear seat area of the Z ... one of the CV outputs would have to be extended / combined with a driveshaft to power the rear axle.
The other CV axle would have to be attached to a driveshaft to run up front to another diff / axle assy ....
The front end is the tricky part .... maybe easiest to make a leaf spring set up off a 4 WD jeep or pick up truck of some sort or is there some other independent system that could be figured out (possibly some transaxle set up but how to power that with the other CV from the ALH 5 sp transaxle ?
Anyways, with the engine moved to rear passenger compartment, I'm thinking the engine bay of the Z could be sheet metaled in for a frunk (front trunk).
The front trunk and the rear trunk could make for decent cargo capacity.
What do you think ? Any ideas of how to do the front drive portion or maybe just not be greedy and go for a mid mount 2 wd diesel ?
I am thinking whether 2 wd or AWD the diff in the transaxle either has to be turned into a limited slip (if AWD) or welded if doing RWD only ?
Thanks in advance for any and all help.
Andrew
Andrew
