Ive been talking with Gruven Parts about doing a billet aluminum block to bolt to the side of the head that improves clearance issues with ALH swaps..
it would replace the plastic (AT) or aluminum (MT) flange with a block for coolant nipples or AN fittings that mounts directly to the head and keeps clearance over the transmission to a minimum..
If possible it would retain the temp sensor and outputs for Rad/EGR and Oil Cooler so nothing would be lost, but you could plug those threaded outputs if you don't need em.. but if this adds too much bulk it may be best to make it a simple 90 degree redirect to the front of the motor, delete EGR, and then put the temp sensor and a wye some place for oil cooler with out clearance problems.. if you wanted coolant to exit the rear of the motor it could be flippable.
I was inspired by this piece they already make: https://www.gruvenparts.com/billet-vw-audi-1-8t-1-9tdi-2-0-upper-radiator-hose-4y/
They said they could do this for about $160 a pop, which seems reasonable for a piece like this.. but to justify the first batch we'd need 20+ people willing to pre-purchase.
Is there anywhere near that much demand or interest in a low profile billet coolant flange for ALH (and perhaps other engines)? I search through conversions of various types and see this flange presents problems for many moving it to an inline config.
I've got backup plans, probably will cost me more money for less.. but if we could get a part on the shelves that would avoid a bunch of us creating one offs it may get more swaps going with less obstacles in the way.
