Lift for TDI Sportwagen (for oversize tires)
Tim's2011Golf
Nova Scotia, Can
2011 Golf Comfortline TDI wagon CR
Well almost all my parts are here. I took apart the car and found 2 broken springs (one front and rear) strut mounts were toast, and one front sway bar link was loose and ready to fall apart. Another order of stuff to get the link and new strut mount bolts as I had to cut a few off when the rusty rivnuts decided to spin..... I ended up getting Blisten shocks, and springs same as the ID parts kit. Being in Canada the shipping was a bit much so ordered from a reputable parts supplier in N.S.
Hi. I live in NS also. Where did you locate the parts you needed?
Cueballsi
Washington
JSW 2012
Did you end up with the B6 struts and shocks? How were they.
I was thinking of doing the JSW front B4, and the Tiguan B4 rear. Based on IDparts suggestion
Still trying to finalize the suspension upgrade I want to do on the JSW. Wasn't completely sold on lift springs/spacers and originally was just going to upgrade to the b6s w/new stock height springs but after reading all 19 pages and distilling it down, here is where I have arrived:
*Only really to need to read the last 3 or 4 pages of this thread.
*Lifting with struts/springs more advantageous than spacer kits such as forge.
*Bilstein B6s up front and B6s in the rear unless there is a reason to consider the b4s?
*IDparts lift springs set unless there is a strong argument for OEM tiguan F/JSW towing R?
FWIW, I currently have 225/50R17 Michelin Crossclimate 2's on my stock height JSW TDI that have been absolutely outstanding year-round here in Colorado. 3 peak rated, so good in the snow that I didn't even bother swapping to my snow tires last year (I am not saying these are as good as a dedicated snow tire, but if you can only have one set these are something to definitely consider). Amazing in the rain, even in downpours I don't need to reduce speed until visibility becomes an issue.
This larger plus 1 tire size will affect the speedometer readings by about +1 at 30 mph, +2 at 60 mph, +3 at 90mph, etc. Haven't worked out the exact MPG penalty but the cars reading has stayed consistent at around 41mpg with both the stock and plus 1 size. I'm sure there is some way to work this out but I haven't bothered.
As for some folks who think the larger tire size with affect the clutch on my manual, I am open to reasoning but I doubt it. My winter setup is 16" steel rims with Bridgestone Blizzaks and I am almost certain they are heavier than the Crossclimate 2 w/stock 17" alloys. I haven't weighed them yet but I will update when I rotate or swap the tires.
Just trying to contribute as I have been scraping information off this forum for years, time to give back. Hope some of the info helps. Will update once I make time and do the suspension/brakes.
Cueballsi
Washington
JSW 2012
OK, Update: Koni is not the way to go; I have blown two struts thus far....
New setup below, so far feels even better.
Bilstein B6 HD Strut and Shock Set (A5 and Mk6 Sportwagen)
- Front Strut Mounts: Yes
- Installation Bolt Kit:
- Rear Shock Mounts:
$1,109.67
2​
Rear Sway Bar Link (Mk5)(Mk6)(NMS)(8P)$37.90
2​
Rear Sway Bar Bushing (A5) [FEBI]$31.22
1​
Eibach Anti-Roll Rear Sway Bar (A5)(Mk6 Golf)(Sportwagen)$249.95
2​
Sway Bar Link (A5)(Mk6)(NMS)(MK7)$36.20
1​
Eibach Anti-Roll Front Sway Bar (A5)(Mk6 Golf)(Sportwagen)$259.95
1​
Sportwagen Lift Springs Set$214.00
How did your set up turn out?
Noticed the B6 fronts are the same for the Tiguan as well as the JSW.
I am sorta on a budget so thinking of the B4s
Cueballsi
Washington
JSW 2012
Regardless of your research, I can tell you what worked for me. Going to Tiguan struts solved my clunk. No noise whatsoever in the rear.
When you talk about "extension", are you talking about the range of the travel? The Tiguan struts may have similar or less range of travel between full compression and full extension, but if that range sits and inch or two higher than a Jetta strut, then that would prevent overextension of the strut by the spring...
So for struts and shocks, you ended up with JSW in the front and Tiguan in the rear?
Did you put new top hats or used the old ones? I am at 114k now. New hats and stops is about $220😳
