jaed_43725
I have read everything I can about changing my idle speed. I talked to my tuner about it and they are saying that the idle speed is controlled by the chip and changing it with VAG-COM is only good for when its hooked up. Is this so? From what I read I can just change it using VAG-COM. If this is so how do you go about making it permanent? Also I read that I need to change the timing. Is this a software change or actually rotating the timing on the IP? The more information the better. Thank you.
