TITLE EDIT: "HOW MUCH VACUUM SHOULD N75 OUTPUT ON MAX VANE DEMAND"
Having underboost issues.
Tied mightyvac into vac system and I get full 27" or so all throughout vac system and into N75. But out of N75 (to turbo) I get 10" on idle, and 13-14" on pedal floored.
Since turbo requires ~18" on actuator to open vanes fully, would this not point to N75 issue? (IE, not enough vacuum to fully open vanes, thus causing underboost and severe lag where some boost kicks in and higher RPM?)
Trying to confirm correct values before throwing parts (don't have known working one to swap-nostic with). Can't find much advanced info on vac issues.
PS. Tested N75 connector resistance at about 17.7ohms
It's 02 Golf TDI ALH. Anyone have these numbers? Or ideas?
