myride4now
I purchased a TDI w/ 36k about two years ago. Its running fine at 70k. I plan on keeping the car well into 2-300k. Anyone having good experiences with theirs?
What's the intake manifolds going bad from?Don't own one, service a bunch of them.
Lots of DPFs (even more than before)
Lots of intake manifolds
Turbochargers here and there still
Various other sensors and stuff, much of which is relatively expensive and often difficult (time consuming) to access
Unfortunately, and ironically, the one surefire way to lessen the issues is with a full delete, and I find this awful myself.
I don't "dislike" these cars, but I certainly don't like them as much as the older ones (which, despite their age and ever climbing numbers in the odometer, seem to just keep on going and going and going....)
Oh, that's another runaway prevention thing within the runners? I bet the oily soot does them in. Another win for fixed emissions.P0215 is common, intake flap motor. You can buy a machined bracket that fixes this. Or tune it out. This fault isn't just a tdi problem.
Hah yeah, I would've had more miles on it if it weren't for COVID and work from home. I hope to hit those miles much sooner! I am hoping the Passat will be my 'forever' car or at least until electric cars have decent range/price/cost of new batteries go down, etc.So.... you have had a car for two years and put 40k miles on it... that's cute.
I hope (and I sincerely do, as Volkswagen's biggest fan) you can still be here a decade from now with 1/4 million miles on that same car and still be going strong.
Jetta BEW went to 2005 and the Golf BEW went to 20062004 Jetta or Jetta wagon, 2004-05 golf
Perfect example of the issue....complexity. Everywhere you look, every system is more complex and I would wager less robust. The EA888's micro coolant circuit would be one of the many examples of where simplicity was thrown out the window in the pursuit of _____ (fill in the blank).ALH intake = one simple aluminum casting with zero moving parts
CJAA intake = a casting, a molded plastic housing, a shaft and bushings, flap valves, torque limiters, a lever, a spring, ball sockets, an actuator consisting of a stepper motor, two parallel feedback sensors, inside of its own aluminum and plastic housing, the whole mess held together with ~20 screws.... collectively about 100 individual parts.
Let's see, one part, or 100 parts. Which do you think will break first? And that is JUST the intake manifold.
