My 2014 Jetta started having DPF/NOx problems just after the warranties ran out.... attempted regen many times, more recently I even used Ross-Tech's vag-com and VCDS to try to force regeneration without success.
Most recent scan:
011174 - NOx Emissions Exceeded P2BA6 - 000 - SCR Catalyst Malfunction - MIL ON
006744 - NOx Catalyst P1A58 - 000 - Regeneration Required
006481 - Radiator Fan 2 (V177) P1951 - 000 - Movement Restricted / Jammed
So the problem first began within a few months of purchasing this 2014 Jetta in Feb 2022. The DPF light came on during one of many trips between San Diego and Phoenix. I had no idea what it was at the time, so pulled over to do some research. I wasn't able to clear it that trip, but watched many YT vids and talked to a mechanic at a Phoenix VW dealership and eventually managed to take care of it. That happened a few more times over the next months, but when the Jetta hit about 122,000 miles, just past the 120k warranty limit, the DPF light just stayed on, or went out but came back on. Then the engine light came on too. I was unable to address the situation the same way I had before, just driving in sport mode keeping rpms around 2000-2500.
Back in San Diego, I asked around for someone to pull codes and was able to borrow a VAG-COM cable. The scan showed pretty much the same results I get today (below). The standing regen was unsuccessful. All attempts at a driving forced regen have also been unsuccessful. I thought I had it lat one point last week and then had to return the borrowed cable.
I got the Ross-Tech cable yesterday and tried the forced regen while driving again last night. After over an hour, both dash lights went out and they stayed out longer than an hour for the entire return trip. I was so relieved and proud of myself. However, both the DPF and engine lights came back on when I started the car up again this morning and I am just disappointed and frustrated all over again.
As I was attempting the regen last night, my soot level increased from something like 6 to just over 15 over the entire 2.5 hour drive. They never decreased and I had read that you know when the regen is finished when that soot number gets close to 0. Is that right? (How DO you know when regen is complete???) I read somewhere else that the regen cannot run unless soot levels are over 40, and mine has never come close to that so I'm confused about that.
I was talking to someone at a nearby VW dealership about it yesterday and they again made it sound like it shouldn't be difficult. They told me it would be $380 plus labor, probably 2 hours, more than it was in Phoenix. I bought the cable and converter for about $250 total including 2-day delivery and felt confident that I could do it myself so I tried. So when the lights were on again this morning, I brought her in hoping to just talk with someone and get some guidance but they weren't willing to entertain me. They wouldn't even let me talk to a service manager.
A scheduler said I could leave my car and they'd probably get to it by Tuesday or Wednesday but I'm supposed to be back in Phoenix ar
ound that time and in CO the following week. Besides, that's just to check it out and who knows how long it would take from there. The scheduler seemed to know about DPF issues and said it should be fine for the trip. He told me to just be sure I fill it up with biodiesel as lower quality diesel might be the problem. I'm like how could that be when I fill up at different places between San Diego and Phoenix all the time? I asked how to identify biodiesel and they sent me to 7-11, which has the same damn diesel #2 every other station with diesel has, but for $6.66 a gallon v. the $6.09 at the cheaper gas station in the area.
The scan I ran this morning looks pretty much like the scans from last week. Please help me figure out what I'm missing! Is there something else I need to address first? Here is today's scan:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 47 56 75 77
VIN: 3VWLL7AJXEM423478 Mileage: 198490km-123335miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 M HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H16--- Serial number:
Coding: 0050078
Shop #: WSC 46723 003 1048576
VCID: 382924AEAE5540BB1F3-806C
VINID: 0E69DC70745AA1574408310720045257F5
3 Faults Found:
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 198340 km
Time Indication: 0
Date: 2017.03.05
Time: 11:28:30
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Pressure: 1004.3 mbar
Temperature: 19.8°C
Mass Air / Rev.: 265.0 mg/str
Temperature: 36.9°C
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 7
Reset counter: 255
Mileage: 198340 km
Time Indication: 0
Date: 2017.03.05
Time: 11:28:32
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Temperature: 19.8°C
Mass Air / Rev.: 260.0 mg/str
Temperature: 36.9°C
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 27
Reset counter: 255
Mileage: 198340 km
Time Indication: 0
Date: 2017.03.05
Time: 11:28:48
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Temperature: 36.9°C
Temperature: 87.3°C
Temperature: 19.8°C
Lambda: 9.5 %
Lambda: 0.0 %
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 521 9430
Revision: 05652104 Serial number: 00001312200437
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 1471B01ED27D44DB53B-8040
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C492400FD850F02EB92210042A1100012
Shop #: WSC 02258 002 1048576
VCID: 0451805EAE1DD45BC3B-8050
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BN HW: 5C0 820 047 BN
Component: J301 Klimaanlage 0204
Revision: 2001001S Serial number: 00000002044113
Shop #: WSC 00000 000 00000
VCID: 6D87C5FA919735133C5-8038
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 L HW: 5C0 937 087 A
Component: BCM25 JLB H3 H34 0425
Revision: B2034001 Serial number: 08013065140014
Coding: 7B994B9A08AB0B0008382000240884C50082502E60000000300050002000
Shop #: WSC 28212 003 1048576
VCID: 36352A96A841B6CB0DF-8062
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14202585140213201312
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Serial number: 14102584140215194400
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Serial number: WRH000B1KFH
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0037
Serial number: 0405238 FLE 20140104
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587140211192516
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14102586140215220302
Coding: 800000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 AD HW: 5C0 959 655 AD
Component: AirbagVW10 102 0912
Serial number: 003MVD03GY81
Coding: 00004138
Shop #: WSC 00066 790 07030
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 74B1D09EFE3DE4DBF3B-8020
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y1400012MSF0/
Coding: 303036
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME48575D41ZZZ/
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME72621941ZZZQ
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME485E0A2BZZZ0
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME275D0D2BZZZ0
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME3153512AZZZO
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME664C512AZZZ+
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C6 920 953 A HW: 5C6 920 953 A
Component: KOMBI H04 0809
Serial number: 00000000000000
Coding: 270A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2B030BE26383FB23621-807E
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H34 0425
Revision: B2034001
Coding: 102200
VCID: 70B9DC8E8AA5D8FB173-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0809
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DCEE6ACF9222B597-803E
Address 2E: Media Player 3
Cannot be reached
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 392F21AA955F59B3E0D-806C
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H08 6815
Revision: -------- Serial number: EAA098A0117888
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3_VW36.rod
VCID: 2615FAD67861C64BBDF-8072
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
Component: Radio Prem-8 H07 0008
Revision: -----11S Serial number: VWZ4Z7P3544887
Coding: 01020040010006
Shop #: WSC 00066 000 00000
VCID: 2B030BE26303FB23621-807E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 126
Mileage: 198493 km
Time Indication: 0
Date: 2017.03.05
Time: 19:53:54
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140515
Coding: 02630102C2163A007F1606000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_OCULow 001010
ROD: EV_OCULow_001_VW32.rod
VCID: 53F373021B7383E30A1-8006
1 Fault Found:
2103041 - Control Module
B1788 F0 [009] - Start Prohibition Deactivated
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 8
Fault Frequency: 1
Reset counter: 126
Mileage: 198493 km
Date: 2022.10.13
Time: 19:53:56
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007665617798
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 2E0502F650918E0B45F-807A
End----------(Elapsed Time: 01:45, VBatt start/end: 14.0V/14.1V)-----------
