This one may be kinda long... lol
Looking to revive my 1981 Rabbit 1.6L diesel, it has been sitting for probably two years.
Little back story, this was my first VW, the one that got me hooked on German Diesel’s, it cost me $500, was/is rustier than heck and I loved it. Coolant temp sensor quit working one day and it overheated, blew the head gasket. So, with my limited knowledge, I set out to replace it. Hopefully I can remember everything in order here. The head has small cracks between the intake and exhaust valve seats, may be important to mention, I don’t know. From my researching at the time that seemed to be fairly common so I wasn’t worried about it.
Anyway umm, I had put it all back together and it did run (somehow haha) but did not like starting.
Now, there are two, possibly three problems I am aware of now (several years later and after doing several TDI timing belts and just learning more about VW diesels in general).
Number one is; I’m pretty sure my cam timing is off slightly, somehow I think I missed the part where you loosen the cam sprocket? (what was I thinking, I know) anyway it’s not off much I’m sure, I know I rotated everything by hand before starting it back up.
Number two problem (and this is the main one I had trouble with); Compression leaking past #4 injector, I replaced the crush washers twice I think. If I remember right there seemed to be a crack or some sort of imperfection down where the washer seats in the head. This is what I would really like help with if possible.
Possible third problem is the injection timing might also be out somewhat, I’ve never checked it, and I know my old boss advanced it, and it was considerably peppier afterwards...
At any rate this, as well as the first problem, are not terribly difficult to fix, but I would be very interested in any and all opinions on Problem two, as well as the whole crazy story, and if you wish to criticize the old me that did these ghastly things well.. go ahead? I’m not sure what I was thinking either hahaha.
