Cha2ga
Anyone have a clean alh (00 beetle) manifold that's already clean? Never done my manifold and at 155k I'm sure it needs it. I could do the R&R with some supervision and swap manifolds. We could work out compensation.
I do, too if you exceed Dan's supply.Anyone have a clean alh (00 beetle) manifold that's already clean? Never done my manifold and at 155k I'm sure it needs it. I could do the R&R with some supervision and swap manifolds. We could work out compensation.
No boost gauge. That's the plan eventually just haven't gotten there yet. I wouldn't even consider myself a wire/electronics novice. So I would glady love to know how to wire this bad boy in. Plus I'd also like to know how to check my turbo too. I'm always up to learn new thingsMichelle, easy repair. I'll bring some wire loom/wire ties and show you how to do it.
Do you have a Boost gauge? Kinda mandatory to monitor the health of your turbo. (Hint). Look at new south performance for some nice kits. Again, supervision is available to help YOU install it......
You will need some EGR block off plates, if not already in place.I have two TDI's that I would like to get some work done on at the GTG. First is a 2000 Jetta TDI, would like to install a frost heater, also like to get the Malone 1.5 stage tune with the EGR delete, and intake manifold cleaning if a spare one is on hand or just clean the old one, and do the snap on mod for the top engine cover. The next is a 03 Jetta TDI, needs transmission fluid changed, snap on mod for top engine cover. Any recommendation as to what part and fluids I should order will be helpful. Thanks!
If I make it I'll bring tools and my VCDS.
Newboyz, can you do a tune on my 2012 while there ?
DSG and stage 1.5, I should have the loose cash by then.
Check the Harbison, SC, Irmo, SC and St. Andrews, SC areas. There are many to choose from and should be fairly close to the GTG.... and apparently there aren't any hotels in Chapin that I have been able to find. I'll check further when I have more time to look into it but this ...
Absolutely. Go for the 1.5. It is awesome. And Andrew did an awesome job for me.Get the 1.5, I started with the 1 and upgraded with in 6 months, happy with both.
Cool- I might have a bad radiator fan (which is how I found this post). I'm assuming that would be easy to help with- I just don't have anything to raise my Jetta up.I doubt if your intake needs cleaning again. But it is easy to remove the EGR valve to peer down the intake and find out.
