jimbote
Certified Volkswagen Nut
Any one make an adapter for mounting a volvo gtb2056vl to a BHW/AFN manifold? Also would Nictane .275 injectors be a good match for this turbo?
yes, this would be for my "VE'd" BHW tacoma power plant.Now would these be on your VE'd BHW?
If so, I would say .275 and an 11mm pump sounds about right for your 2056.
cheers,
Douglas
Get the turbo to a decent welder so he can cut and weld a new flange to the gtb2056vl turbo... This will make it an easy install !Any one make an adapter for mounting a volvo gtb2056vl to a BHW/AFN manifold? Also would Nictane .275 injectors be a good match for this turbo?
the volvo VL turbo has a unique housing. I have one of those adapters for a gtb/vk turbo, nice piece but does not fit the VL.@jimbote Is this one the same? https://www.darksidedevelopments.co...er-flange-for-1-9-and-2-0-tdi-pd-engines.html
I was thinking of ordering one for a GTB2260VK. If I go that route. If someone stateside made one that would be cool.
Hello. I plan to install on my Passat B5+ exhaust manifold 028253033Q and turbo gtb2056vl. How can I get your flange drawing?How close to the block you want to install the turbo? If you need it to sit like the original BHW turbo, I can suggest you a manifold and I can give you a CAD drawing to cut a flange for it. The manifold is 028253033Q.
