GTB2056VL Adapter and injector question.
PakProtector
AnnArbor, MI
Mk.4 and the Cummins-es
Now would these be on your VE'd BHW?
If so, I would say .275 and an 11mm pump sounds about right for your 2056.
cheers,
Douglas
adamss24
Great Britain
Any one make an adapter for mounting a volvo gtb2056vl to a BHW/AFN manifold? Also would Nictane .275 injectors be a good match for this turbo?
Get the turbo to a decent welder so he can cut and weld a new flange to the gtb2056vl turbo... This will make it an easy install !
arazvan2002
Romania
Audi A4 B6 1.9TDI AVF quattro
How close to the block you want to install the turbo? If you need it to sit like the original BHW turbo, I can suggest you a manifold and I can give you a CAD drawing to cut a flange for it. The manifold is 028253033Q.
