dieselpower04
Ok we moved across country and are in the process of buying a house. I will have a 6 minute drive to work and that can't be good for the car long term. And again, with the kiddo and dogs, the Golf has gotten a little small for our life.
All the details are in the build thread but very quick run-down:
Car now has 187,XXX miles on it.
Titled and registered in Maine.
VWMikel Stage 3 tune
PD150 injectors
PD150 Intake manifold
PD150 Turbo Inlet pipe
R32 Airbox w/Euro DSG snorkle
VNT-17/22 turbo
Audi TT short shifter
Audi TT lower control arms (with adjustable camber)
Matt Whitbread custom FMIC
3 bar MAP sensor
Frank06 Stage 2 cam w/ black lifters and oil-mod bearings
SBC Stage 3 clutch
BFI Stage 1 motors/tranny mounts
OZ Alleggerita HLT 17" wheels (16.1 lbs/piece)
KW V2 coilovers (height adjustable and dampening adjustable)
Last dyno 182 whp/335 ft-lbs.
$8,500 OBRO!
What it needs currently:
Parking brake cable adjustment
Valve cover gasket leaks slightly
As it currently sits:
Brand new all-season Touring Toyo Tires (195/65/15) on the 15" OEM wheels.
Blower motor resistor pack installed.
Needs a timing belt at 190k miles.
PD150 injectors
VNT-17/22 turbo
3 bar MAP sensor
SBC Stage 3 clutch
$8,500 OBRO!
