There are 2 Exhaust Sensors on my 96 Passat TDI. I can't find where the Temp Sensor connects under the hood. Any help would be great. Thanks.
Exhaust temp.Not sure what you're asking... Are you wanting exhaust temperature or coolant temperature or something else?
They didn't have an exhaust temp sensor from the factory, that gets added later if you want it. The later ones (2004-2005) had an exhaust temp probe from the factory, but not the 1996. You're probably looking at the 5th injector stuff, unless someone already added an egt probe.Exhaust temp.
Would be interested in knowing the build date for the car in question, sounds to me like a transplant from a 96 Passat.My brother in law's 1998 Jetta has the parts for a fifth injector. Not sure why. I've never seen that before, I thought it was only 1996 passats that had it.
That's what I wondered, but if I remember correctly it has ahu stamped on the block. And who would transplant all of the garbage with it? It has a code for the fifth injector which triggers a check engine light as well.Would be interested in knowing the build date for the car in question, sounds to me like a transplant from a 96 Passat.
Steve
A VIN would be helpful with this, and for a Mk3 of that year to come with that garbage on it would be strange, almost as strange as a '98 Canadian Jetta with the AAZ engine in it, no airbags and passenger glove box....That's what I wondered, but if I remember correctly it has ahu stamped on the block. And who would transplant all of the garbage with it? It has a code for the fifth injector which triggers a check engine light as well.
Here's the vin number for his car. I'll see if I can get some photos on the fifth injector paraphernalia. 3vwrf81h5wm123448A VIN would be helpful with this, and for a Mk3 of that year to come with that garbage on it would be strange, almost as strange as a '98 Canadian Jetta with the AAZ engine in it, no airbags and passenger glove box....
I have a hard time believing that it came that was from VW, for US import.
Steve
Did some of them have that fifth injector?Yep, that is an A3 Mexican Jetta VIN.
TDI too, so not a gasser transplant. Who knows, maybe a guy on the line saw a "5th Injector" code on the trunk sticker, and put it in.Yep, that is an A3 Mexican Jetta VIN.
I can understand that scenario though. Aside from the fact they do questionable work, if you have one donor you take it all, and in this case it sounds like they had a donor that had not gone through the recall, so they used it as is.Clown-ass NCC put the 5th injector garbage on my red car using the black plastic BK ECU. Some peoples' children I tell ya. Best bet is to use the FAQ's on this site and delete the hell out of that system. A couple resistors and you're good to go.
