Benjamis
Maybe scoring isn't the right word, but would you guys do anything about this?
I have a low oil pressure issue still after replacing the intermediate shaft bushings. Camshaft journal clearances are all below 0.002", as checked with an indicator not plastigage. Lifters and cam are brand new and the bores are all in the 1.378-1.379" range. I measured new lifters to be 1.376". Oil pump is in spec according to Bentley. No more oil leaks.
The oil light flashes a couple times on cold start, and I get the buzzer on hot days with hot engine between 2000-2500 rpm. I tested the sensors and they are good. The oil pressure gauge reads as low as 13psi at the head and 22psi at the oil cooler at 2k rpm, and about 8.5 at idle.
I'm looking to replace the rod and main bearings and rings. These marks on the cylinder wall aren't close to catching a fingernail but would you freshen them up somehow or not worry about it? I think the oil came from when I pulled off the head, but not totally sure.
