I'm familar with that document and have read and looked at it many times. If you had looked at it carefully and knew how the fuel flowed through a hpfp then you would have known that the screens/filters you are talking about are before the fuel metering valve and before the overflow valve and NOT in the main return fuel port. Yes,fuel does return through the overlow valve when the fuel pressure is over 62 psi. Look again at the drawing and you might understand it this time. Since I have a hpfp to actually take apart and examine, its way better than your paper verison that you are basing your knowledge on. Maybe you need to revise your theories.
dweisel
Before/IN, same difference in this case! Let's not split hairs, please.
Also the overflow valve that you are refering to, it also serves as a pressure metering valve that meters the fuel OUT the low pressure fuel return.
The fuel delivered by the Auxiliary Fuel Pump V393 acts in opposition to the piston and the piston spring of the overflow valve. With a fuel pressure over 62 psi (4.3 bar), the overflow valve opens and clears the way to the fuel return. The excess fuel flows through the fuel return into the fuel tank."
Pg. 38. of the training book serves my point. The fuel will flow through the fine filter prior to leaving the HPFP unit through the low pressure side above 62psi which is where the pump internals sit the marjority of the time. Yes, some fuel does leave through a metering orifice prior to 62psi unfiltered but its only a small amount while the pressure inside builds as the low pressure fuel pump starts up. The low pressure fuel pump is always supplying 73psi.
My MAIN point that I'm stating, is that the majority of fuel goes through a pair of fine filters before leaving the HPFP. Whether its through the return or prior to the HP metering valve. IF those filters get clogged, WHAT WOULD HAPPEN? Question to a theory, thats all. It seems to me those filters would clog quickly in a bad fuel event?
In the event of a HPFP failure, these filters clogging would restrict all flow to the CR and back to the fuel tank. We do know that metal chips get back through the entire system, so do these fine filters break away because of the clogging and then flow through the entire fuel system?
